Arduino keyboard help
So I need to hook up a small keyboard
and when I input numbers I want them to be read as numbers, not their ascii values.
I know the trick of - '0' but this only works for 0-9, I need to feed it larger integers like 17.
When doing it with a standard laptop
http://forum.arduino.cc/index.php?topic=220089.0
this program did me fine. Any suggestions would be much appreciated.
How are you planning to recognize that the last digit of the number has been entered?
sorry are you referring to me using my computer to send the data or just the keyboard?
Say you want to enter the number 76521.
What buttons will you press? How does it know the difference between one number 76521 and two numbers: 765 and 21?
Oh sorry I see what you mean, so I have coded it so that It takes each number alone, so if I wanted 11 for example I would hit 5, A, 6, A, D, A.
so A just sends the digit to the arduino, when I send D it tells the arduino to add all the input. not the best way of doing it by any means but it works. The issue i'm running into is when I do 5, A, 6, A, D, it adds the ascii values of 5 and 6, not their integer values.
Then I have an if statement for the outcome:
for example;
if (outcome = 11){
digitalWrite(motor, HIGH);
but when it adds ascii values the outcome isn't even close, I could always just code for adding ascii values if this cant work
perhaps consider using the # or * key to terminate an entry.
read the values into an array of bytes as they are input until the key you use to terminate is pressed # for example and terminate the char array with a null.
then evaluate the number entered, using the length of the array to tell you what to multiply each digit by,
last digit by 1 2nd from last x 10 third from last x 100 etc... so if 5 digits added you will have some 10,000s
in your array at index 0 1000s at index 1, hundreds at index 2 tens at index 3 and units at index 5.
allowing you to hit 1, 1, # to enter 11 :wink:
better than my solution :smiley: ill try it out, thanks
edit to above.. units at index 4..
