Hi. I'm trying to build my own keyboard using an arduino pro micro, but I'm having some trouble with the code. I'm trying to set up a 2 dimensional array for all my keys, and most of them work fine. The problem is the modifier keys. For keys like the space key, when I call them as Keyboard.press(KEY_SPACE) it's fine, but since I'm using an array in the code it's called as Keyboard.press(layout*[j]), and when it points to KEY_SPACE in the array, it outputs , for some reason. There's a similar problem with all the keys, like shift. With shift when I put Keyboard.press(KEY_LEFT_SHIFT) in the setup section and then press a key it capitalizes that key normally, but when the layout calls KEY_LEFT_SHIFT from an array, it doesn't do that.*
Here's the code:
*#include <HID-Project.h>
#include <HID-Settings.h>
#include <Adafruit_MCP23017.h>
Adafruit_MCP23017 mcp;
byte inputs[] = {4, 5, 6, 7, 8, 9};
const int inCount = sizeof(inputs) / sizeof(inputs[0]);
byte outputs[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14};
const int outCount = sizeof(outputs) / sizeof(outputs[0]);
char keys[2][2] = {
{KEY_LEFT_SHIFT, 'j'},
{'k', 'w'}
bool keysDown[2][2] = {
{false, false},
{false, false}
mcp.begin();
for (int i = 0; i < outCount; i++) { //declaring all the outputs and setting them high
mcp.pinMode(outputs[i], OUTPUT);
mcp.digitalWrite(outputs[i], LOW);
for (int i = 0; i < inCount; i++) { //declaring all the inputs and activating the internal pullup resistor
pinMode(inputs[i], INPUT_PULLUP);
Keyboard.begin();
keyCheck();
void keyCheck()
for (int i = 0; i < 2; i++) {
for (int j = 0; j < 2; j++)
if (digitalRead(inputs[j]) == LOW && keysDown[i][j] == false)
Serial.print("Row: ");
Serial.print(i);
Serial.print("Col: ");
Serial.print(j);
Keyboard.press(keys[i][j]);
keysDown[i][j] = true;
Serial.print("KeysDown set to true");
} else if (digitalRead(inputs[j]) == HIGH && keysDown[i][j] == true)
Serial.print("keysdown set to false");
Keyboard.release(keys[i][j]);
keysDown[i][j] = false;
delay(1);
mcp.digitalWrite(outputs[i], HIGH);
I'm using an arduino pro micro, and the library I'm using for the keyboard is NicoHoods HID library
Sorry, I'm not great at explaining things, so let me know if you need any clarification or have any questions or anything.
Thanks
