I am currently trying to use my arduino mega to read out input from an electronic dartboard.
i already identified how the matrix of the dartboard is built and connected everything to my arduino mega.
(It's a 4x20 matrix
with the 4 rows being single, double, triple and bullseye
and the 20 columns are the numbers from 1 to 20)
Now to my actual question, i wanted to (mis)use this library to get the data and it seemed to work fine at first, until i realized that the last 4 columns didnt give a response.
I tried using diffrent pins but it was always the last 4 i defined using the example from the library.
So after that i looked into the Code of the Library itself and found this line:
#define MAPSIZE 10 // MAPSIZE is the number of rows (times 16 columns)
and this line:
uint bitMap[MAPSIZE]; // 10 row x 16 column array of bits. Except Due which has 32 columns.
in both cases in the comment it states something about 16 columns (which i guess is somehow defined as the max )
i couldnt find where this 16 comes from and how i can work around that.
so if anybody with a little more C knowledge than myself can help me out by finding where this 16 comes from and how i can increase that to 20, i would be very grateful!
Cheers
