Hello, I recently bought an Arduino Uno; I want to use the L298N DC motor driver module but I have a problem.
At the beginning, when I prepared and tested it, everything was working correctly and without violation; its Gnd was shared with the Arduino Gnd, and it worked perfectly with 5V input and the regulator in the circuit. it obtains its logical voltage; Its H-Bridge also controlled the complete direction of rotation without any problem with full power and precision. (there was no problem in controlling the rotation speed)
But after a few days, I used it again for another test, and surprisingly, when I connect them to Gnd, the DC motor stops moving and not even a noise comes out of it; (The 5V DC motor that I have does not rotate below 20% of power and only makes noise)
If I don't connect the Gnds together, obviously the circuit will not be established and the chipset will not work properly
But now I made an interesting discovery. Now, if I remove the regulator jumper and supply its logic voltage separately (using the 5V output of the Arduino), it works perfectly as before.
I don't think the regulator or any of its associated components are at fault because I didn't over-voltage and didn't damage the board either.
Thank you for helping me, I have a strange problem!
