Arduino LabView temperature problems.
Hi!
When connecting a TMP36 tempsensor to the arduino and measuring it with labview, the measured voltage from the sensor is varies a lot when i put my hand close to the USB-cable or the any of the other wires. I have tried to connect a pull-down to the tempsensor without success.
Does the value change if you just print it to the Serial Monitor?
PaulS: Does the value change if you just print it to the Serial Monitor?
Yes it does :(
Yes it does
Then it isn't a LabView problem, or an interfacing with software on the computer problem. It's a hardware problem.
PaulS: Then it isn't a LabView problem, or an interfacing with software on the computer problem. It's a hardware problem.
I have tried with two different arduinos, two sensors, two USB-cables. Can it be the power from my macbook?
Maybe. A schematic and photo of your setup might be useful.
PaulS:
Yes, i will upload when i get home
