Arduino + LabView using LINX || collect2.exe: error: ld returned 1 exit status
[ITA]
Buonasera,
riporto l'errore che salta fuori ogni volta che provo a compilare un programma basato sul firmware fornito da LINX, col quale sto cercando di mettere in comunicazione Arduino + DHT22 e LabView.
Non sono un esperto per quanto riguarda questa tipologia di messaggi di errore, quindi mi rifaccio a voi, se avete qualche consiglio da darmi.
Grazie in anticipo e spero di non aver fatto qualche strafalcione con la scrittura di questo topic!
[ENG]
Good evening,
here are the error messages I get every time I try to compile a program I wrote. I'm using LINX firmware to make Arduino + DHT22 and LabView communicate.
I'm not really an expert about these error messages so I'm in your hands, if you have some advice.
Thank you very much!
Code and errors:
**  This is example LINX firmware for use with the Arduino Mega 2560 with the serial
**  interface enabled.
**  For more information see:           www.labviewmakerhub.com/linx
**  For support visit the forums at:    www.labviewmakerhub.com/forums/linx
**  Written By Sam Kristoff
**  BSD2 License.
#define DHTPIN 2
#define DHTTYPE DHT22
//Include All Peripheral Libraries Used By LINX
#include <SPI.h>
#include <Wire.h>
#include <EEPROM.h>
#include <Servo.h>
#include "DHT.h"
//Include Device Sepcific Header From Sketch>>Import Library (In This Case LinxArduinoMega2560.h)
//Also Include Desired LINX Listener From Sketch>>Import Library (In This Case LinxSerialListener.h)
#include <C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\MakerHub\LINX\Firmware\Source\libraries\LinxArduinoMega2560\LinxArduinoMega2560.h>
#include <C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\MakerHub\LINX\Firmware\Source\libraries\LinxSerialListener\LinxSerialListener.h>
//Create A Pointer To The LINX Device Object We Instantiate In Setup()
LinxArduinoMega2560* LinxDevice;
//**Forward declaration for the custom command function
int myCustomCommand_dht22();
//initialize dht22 and variables
DHT dht(DHTPIN, DHTTYPE);
float t, h;
//Initialize LINX Device And Listener
  //Instantiate The LINX Device
  LinxDevice = new LinxArduinoMega2560();
  //The LINX Listener Is Pre Instantiated, Call Start And Pass A Pointer To The LINX Device And The UART Channel To Listen On
  LinxSerialConnection.Start(LinxDevice, 0);
  //** Attach the custom command to the LINX Listener
  LinxSerialConnection.AttachCustomCommand(0,myCustomCommand_dht22);
  dht.begin();
  //Listen For New Packets From LabVIEW
  LinxSerialConnection.CheckForCommands();
  //Your Code Here, But It will Slow Down The Connection With LabVIEW
int myCustomCommand_dht22(unsigned char numInputBytes, unsigned char* input, unsigned char* numResponseBytes, unsigned char* response)
  unsigned char h = dht.readHumidity(); // Read RH value from sensor
  unsigned char t = dht.readTemperature(); // Read temperature as Celsius
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t)) {
    return 1;
  response[0] = h;
  response[1] = t;
  *numResponseBytes = 2;
  return 0;
Arduino:1.8.3 (Windows 7), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Lorenzo\AppData\Local\Temp\ccZrAcne.ltrans0.ltrans.o: In function `main':
ccZrAcne.ltrans0.o:(.text.startup+0x14a): undefined reference to `LinxArduinoMega2560::LinxArduinoMega2560()'
ccZrAcne.ltrans0.o:(.text.startup+0x15a): undefined reference to `LinxSerialConnection'
ccZrAcne.ltrans0.o:(.text.startup+0x15c): undefined reference to `LinxSerialConnection'
ccZrAcne.ltrans0.o:(.text.startup+0x15e): undefined reference to `LinxSerialListener::Start(LinxDevice*, unsigned char)'
ccZrAcne.ltrans0.o:(.text.startup+0x16a): undefined reference to `LinxSerialConnection'
ccZrAcne.ltrans0.o:(.text.startup+0x16c): undefined reference to `LinxSerialConnection'
ccZrAcne.ltrans0.o:(.text.startup+0x16e): undefined reference to `LinxListener::AttachCustomCommand(unsigned short, int (*)(unsigned char, unsigned char*, unsigned char*, unsigned char*))'
ccZrAcne.ltrans0.o:(.text.startup+0x196): undefined reference to `LinxSerialConnection'
ccZrAcne.ltrans0.o:(.text.startup+0x198): undefined reference to `LinxSerialConnection'
ccZrAcne.ltrans0.o:(.text.startup+0x19a): undefined reference to `LinxSerialListener::CheckForCommands()'
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
