Arduino LAN IP scanner + antihack
Is it possible to make an Arduino network(LAN) scanner (with an appropriate shield) similar to programs such as http://www.nirsoft.net/utils/wireless_network_watcher.html ? So you can detect unwanted IPs on your network without using a computer.
I am planning to build a system that would detect and contact me when an unauthorized device has connected to my computer(detection of hacking).
yes very well is possible, but 100% safe is quite hard.
think you can get IP address of remote devices and their MAC address, lookup of more details will be limited by RAM
IP and MAC is great for starters. And as far as 100% protection goes, I will consider this project a success if I can detect most of the possible hacks
How would I start to program such an IP scan? I found no similar programs anywhere.
Polisalama: IP and MAC is great for starters. And as far as 100% protection goes, I will consider this project a success if I can detect most of the possible hacks
Start with low expectations, detecting the devices on-line is a good first step.
how would you do it if you were the Arduino ;)
you would go through a list of addresses and check if you can connect to them. (e.g. ICMP-ECHO aka PING) If the device responds to PING you can check all TCP/UDP ports of that device.
If the device does not respond to PING, you still might to do a port scan for that IP as response to PING is not mandatory.
If you get a response you should probably look into the ethernet library where to find the MAC address
This might be a place to start - http://playground.arduino.cc/Code/ICMPPing -
Thanks! :smiley: I think I can work from here.
How about knowing how much bandwidth each device is currently using? Any ideas on how to get that data?
you need a packet sniffer for that.
