arduino+LCD +accelerometer+months stuck=plz hlp!!!
Hi Yalll,
i recently got my hands on an arduino 2009 (ATmel 328) board and a 128 * 64 lcd on ks 0108, despite the pin horrors i got the 2 to work just fine using library and sample code provided on arduino site for ks0108 library.
Now i wanted to add the accelerometer to the circuit. I got a 3 axis low g Accelerometer MMA7260 prototype PCB. This is where the trouble began.
(sureelectronics.net/goods.php?id=176)
I discovered that i need to use the analog inputs (A0-A5) so i can use the analogRead function, if you dealt with that library you know with regular pin assignment that’s not possible, since ks0108 is set up such that you A0-A4 for cs1 cs2 En Di and Rs.
After figuring out how to transfer mentioned pins to digital inputs 0 1 2, 12 and 13. I managed to free up the Analog input pins (A0-A5).
(Done by modifying ks0108.h file as so):
#define CSEL1            12            // CS1 Bit   // swap pin assignments with CSEL2 if left/right image is reversed
#define CSEL2            13            // CS2 Bit
#define R_W            1            // R/W Bit
#define D_I            0            // D/I Bit
#define EN            2            // EN Bit
//#define RES             19            // Reset Bit  // uncomment this to contol LCD reset on this pin
Now connecting the accelerometer, pins and code were set as follows:
(note code used was GLCD example found arduino website with ks0108 library, and was modified only) same is true for modification above.
#include <ks0108.h>
int xr;
int yr;
int zr;
const int s2 =14;
const int s1 =15;
const int xpin =16;
const int ypin =17;
const int zpin =18;
const int slp =19;
void setup(){
 pinMode(s2, OUTPUT);
 digitalWrite(s2, HIGH);
 pinMode(s1, OUTPUT);
 digitalWrite(s1, HIGH);
 pinMode(xpin, INPUT);
 pinMode(ypin, INPUT);
 pinMode(zpin, INPUT);
 pinMode(slp, OUTPUT);
 digitalWrite(slp, HIGH);
  GLCD.Init(NON_INVERTED);
  GLCD.SelectFont(System5x7);
  countdown(2);
  GLCD.ClearScreen();
void  loop(){
xr = analogRead(xpin) ;
yr = analogRead(ypin);
zr = analogRead(zpin);
  GLCD.ClearScreen();
 GLCD.CursorTo(13,2);
  GLCD.Puts("X= ");
  GLCD.PrintNumber(xr);
  GLCD.CursorTo(13,3);
  GLCD.Puts("Y= ");
  GLCD.PrintNumber(yr);
  GLCD.CursorTo(13,4);
  GLCD.Puts("Z= ");
  GLCD.PrintNumber(zr);
my lcd screen with this code shows that both x and y values are 1023 while my z value fluctuates. i know its a pin assignment error in the end. but ive looked at every accelerometer example out there with no help.
if i switched the s2 or s1 to low the values of x or y would become 0 respectively and z would still fluctuate
sorry for the boring details, had t make the picture clear :smiley:
PS this is for a project and values must be displayed on LCD… and 2009 boards come with usb connection and not serial
I know much of this code is useless
So, cut it out, and concentrate on what your primary problem is. You'll almost certainly find that Serial works, so use that, and not some hacked LCD code.
Please go back to your post, click on "Modify" then highlight the code blocks and press the "#" (code) button on the editor's toolbar.
I'd look carefully at this section of code:
const int xpin =16;
const int ypin =17;
const int zpin =18;
I discovered that i need to use the analog outputs (A0-A5) so i can use the analogRead function, if you dealt with that library you know with regular pin assignment that's not possibl,
There is no analogue output on the arduino, you can use some pins as PWM outputs but don't confuse that with the analogue inputs A0 to A5.
sorry what i meant was inputs (A0-A5)..... its still the same question
PS> Issue corrected in initial post ;D as in the output input typo, not the situation............
No, it’s still there.
const int xpin =16;
const int ypin =17;
const int zpin =18;
One thing i forgot to mention is that if i disconnected my accelerometer screen still shows same values....... i know, they seem to be driven by s1 and s2 being high or low ( but how? pin 16 reads 14 and 17 reads 15 thats the mystery).........which led me to conclusion of an internal pin assignment error ......hope that helps you help me lol
No false conclusion.
Can you post a schematic of what you have as I am confused by your explanation. It could be that the input to the analogue pins is too high impedance to work correctly.
xr = analogRead(xpin) ; yr = analogRead(ypin); zr = analogRead(zpin);
That is wrong you don't use the digital pin values for an analogue input.
Look, write a new sketch, correct the analogue input pin assignments already pointed out, and just use simple Serial prints to display the values read from the "analogRead"s on the serial monitor.
About a fifteen line sketch.
ok.... the analog read is being read from pins 16-18 which are (A2-A4)....a Serial sketch might be easier, but this is for a project and has to be displayed on the lcd
First rule of debugging - KISS.
Build on things that you know work, and don't debug two broken things at the same time. When you're getting sensible results from your accelerometer, then plug that code back into your (by now debugged) LCD code.
Pins 16-18 are [u]digital[/u] pins.
thank youuuuuuu thats part of my confusion… then what are A0-A5 are refered to in code?
some examples were 012345 others 14-19 site suggeted A0-A5 but didnt work
PS how do you upload a sketch
The six analogue inputs are numbered 0..5. If you want to use them as digital I/O, then they're numbered 14..19. There's no confusion between analoue 0..5 and digital 0..5 because "analogRead" maps the pin for you, but it doesn't know about numbers 14..19.
I tried that
const int s2 =14;
const int s1 =15;
int xpin =2;
int ypin =3;
int zpin =4;
const int slp =19;
And now all values fluctuate regardless of connection as well
So now you are actually reading the analogue inputs what is connected to them. Try connecting a 10K pot to the analogue inputs and see if you get a steady reading.
You have already done this when you hit the upload button in the arduino interface.
Compile and run this, and post the results, please.
const int analogPin [] = {2, 3, 4};
void setup ()
  Serial.begin (9600);
void loop ()
  for (int i = 0; i < sizeof (analogPin) / sizeof (analogPin [0]); i++) {
    Serial.print (analogRead (i));
    Serial.print (" ");
  Serial.println ();
143 126 143
148 136 128
158 141 125
152 152 131
140 160 138
128 152 152
127 139 159
137 126 155
140 128 138
150 132 128
155 143 127
152 152 128
136 157 140
126 153 150
129 135 160
134 127 151
143 124 139
148 135 127
157 141 124
149 151 131
134 158 138
128 149 153
127 136 157
135 124 152
139 127 134
152 132 125
154 141 126
149 153 128
134 155 140
124 150 151
129 131 158
134 125 149
143 124 133
149 134 127
156 143 123
148 152 131
131 157 138
126 146 154
127 132 155
135 123 149
139 127 131
152 134 123
153 141 126
146 154 129
131 154 142
123 148 152
129 128 157
134 125 147
143 125 130
149 133 126
152 145 123
145 152 132
128 156 140
127 143 156
127 129 154
138 122 145
141 125 131
P.S. while not even connected to accelerometer
and while connected
334 320 338
338 325 341
340 328 336
341 335 340
334 339 336
329 338 339
326 328 340
330 321 337
334 322 341
337 325 336
343 330 340
340 334 338
335 340 338
326 337 340
325 326 336
330 321 341
332 319 337
339 325 341
341 329 341
341 336 335
335 341 340
328 336 335
328 328 341
329 320 336
334 322 338
337 325 339
343 330 336
341 337 340
332 339 336
329 337 340
326 325 338
330 320 336
332 320 341
339 325 336
343 331 341
338 335 335
333 340 340
327 334 339
328 325 338
330 321 341
332 320 336
340 327 341
341 330 336
340 337 342
331 339 341
328 335 338
328 326 341
330 320 338
336 323 340
340 327 336
343 332 338
338 338 341
331 339 335
328 335 341
327 323 336
332 322 341
335 322 338
341 327 336
341 332 340
338 337 336
332 340 341
325 332 334
328 324 341
329 318 339
336 322 338
340 327 341
340 331 336
338 339 341
329 337 336
328 333 340
327 323 340
332 320 338
337 324 341
341 327 338
343 334 341
337 338 337
330 338 335
326 332 340
329 322 335
333 322 341
335 323 335
341 329 340
341 333 339
338 339 337
328 338 340
325 330 335
328 322 341
331 319 335
337 323 341
341 327 341
342 333 337
336 340 340
328 337 335
327 331 340
327 320 336
333 321 341
335 323 340
342 329 337
342 335 340
336 339 336
329 338 341
325 329 336
329 321 337
332 320 340
339 324 336
343 330 341
340 334 335
336 340 341
327 337 338
327 329 337
328 321 340
Are you quite sure gravity is working where you are?
How have you got the range select pins on the accelerometer connected? And sleep mode?
;D that y we need that accelerometer..... yes thats why i was asking how to upload a picture someone asked for a schematic and i thought that was a good idea, but couldnt figure it out
why are the values unstable and nonzero........ the 10k pot seemed to decrease values, but they still fluctuate or it kills to zero. and if so do i need 3 pots in this case
please checkout link on initial post for the accelerometer....... i connect the gnd and 5v from the board and manually set s1 s2 and sleep to high by connecting them to 5v also. and x y z go to A2-A4.... there is an EN clk txd rxd do and di on the accelerometer provider said that i2c is functionless so i thought the last 6 are useless...... did i miss anything
The numbers for x and y would still be non-zero, because the zero point is offset to half the supply voltage. With the device horizontal on a stable surface, x and y should be around 1.65 volts, or about 340 counts. the value of z will then be higher or lower than these, depending on orientation.
