arduino LCD auto new line
hello,
I am building this project: http://www.instructables.com/id/Wiring-up-the-LCD-and-the-LED/
And now i was wondering, Is it possible to auto create a new line when the current line is full?
because the rss feed has long lines, which don’t fit on one line, but does on two lines.
I am using this feed: http://www.alarmeringen.nl/feeds/region/noord-holland-noord.rss
I also have another problem.
When i try to connect to the feed, it says 403 forbidden.
but i can access it trough my browser.
I Included the python and arduino file!
RSS_Feed_Code.ino (3.5 KB)
P2000.py (1.82 KB)
Can you just include a counter to keep track of how many characters have been read in and then set the cursor to line 2 in the display?
Switch libraries.
Use “LiquidCrystalFast” from here:
http://www.pjrc.com/teensy/td_libs_LiquidCrystal.html
You need to fix a couple of bugs.
I atttached my version which has the bugs fixed.
— bill
LiquidCrystalFast.zip (31.1 KB)
Wow thnx!
But im autistic, can you give me detailed instructions of how to do this?
and do i need other components?
install the library using the IDE.
[Sketch]->[Import Library...]->[Add Library...]
Then use LiquidCrystalFast instead of LiquidCrystal.
See the included examples for examples.
The wiring, constructors, and API functions are the same as the LiquidCrystal library.
You can use the zip I provided if you want the library with my fixes in it.
--- bill
wow, thnx for the fast reply and understanding XD
