Arduino LCD via I2C (PCF8574AP)
Hi guys,,, I found the problem on HD44780 (16x2) display via I2C with a PCF8574AP.
when I uploaded the example sketch, there are a few problems. The first line is filled with black boxes.
I'm not able to print text on the display.
is there any solution ??
I use this code
#include <Wire.h>
LiquidCrystal_I2C lcd(0x38,16,2); // set the LCD address to 0x20 for a 16 chars and 2 line display
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.print("Hello, world!");
I use this schematic
budiraharjo:
Yes, there is a solution. Try looking over this thread for starters --> Converting 16x2 LCD to I2C (SOLVED) - Displays - Arduino Forum.
Also, delete your duplicate thread.
Don
do I need to add pull-up resistors on the i2c lines ?
That was spelled out pretty clearly in the thread that I recommended in my original reply, specifically in reply #8. Is there any part of what is said there about pull-ups that you don't understand?
Don
