I have an sainsmart 1.8" LCD that works fine with the adafruit library but I find their examples to cumbersome to edit, and the arduino tft library seems much easier. I am using it with an ethernet shield so I can't use spi on it because of pin conflicts which is fine, but it means I have to manually define my pins for the LCD. When using the example provided with the LCD library I get an error when defining more than 3 pins .. help please.
TFTDisplayText:27: error: no matching function for call to 'TFT::TFT(int, int, int, int, int)'
/Applications/Arduino.app/Contents/Resources/Java/libraries/TFT/TFT.h:17: note: candidates are: TFT::TFT(uint8_t, uint8_t, uint8_t)
/Applications/Arduino.app/Contents/Resources/Java/libraries/TFT/TFT.h:15: note: TFT::TFT(const TFT&)
TFTDisplayText.ino: In function 'void setup()':
TFTDisplayText:37: error: 'TFTscreen' was not declared in this scope
TFTDisplayText.ino: In function 'void loop()':
TFTDisplayText:62: error: 'TFTscreen' was not declared in this scope
The code im using with the arduino tft library is:
Arduino TFT Bitmap Logo example
This example reads an image file from a micro-SD card
and draws it on the screen, at random locations.
In this sketch, the Arduino logo is read from a micro-SD card.
There is a .bmp file included with this sketch.
- open the sketch folder (Ctrl-K or Cmd-K)
- copy the "arduino.bmp" file to a micro-SD
- put the SD into the SD slot of the Arduino TFT module.
This example code is in the public domain.
Created 19 April 2013 by Enrico Gueli
http://arduino.cc/en/Tutorial/TFTBitmapLogo
// include the necessary libraries
#include <SPI.h>
#include <SD.h>
#include <TFT.h> // Arduino LCD library
// pin definition for the Uno
#define sclk 3
#define mosi 5
#define cs 6
#define dc 7
#define rst 8 // you can also connect this to the Arduino reset
TFT TFTscreen = TFT(cs, dc, mosi, sclk, rst);
// this variable represents the image to be drawn on screen
PImage logo;
// initialize the GLCD and show a message
// asking the user to open the serial line
TFTscreen.begin();
TFTscreen.background(255, 255, 255);
TFTscreen.stroke(0, 0, 255);
TFTscreen.println();
TFTscreen.println("Arduino TFT Bitmap Example");
TFTscreen.stroke(0, 0, 0);
TFTscreen.println("Open serial monitor");
TFTscreen.println("to run the sketch");
// initialize the serial port: it will be used to
// print some diagnostic info
while (!Serial) {
// wait for serial line to be ready
// clear the GLCD screen before starting
// try to access the SD card. If that fails (e.g.
// no card present), the setup process will stop.
Serial.print("Initializing SD card...");
if (!SD.begin(sd_cs)) {
Serial.println("failed!");
return;
Serial.println("OK!");
// initialize and clear the GLCD screen
TFTscreen.begin();
// now that the SD card can be access, try to load the
// image file.
logo = TFTscreen.loadImage("arduino.bmp");
if (!logo.isValid()) {
Serial.println("error while loading arduino.bmp");
// don't do anything if the image wasn't loaded correctly.
if (logo.isValid() == false) {
return;
Serial.println("drawing image");
// get a random location where to draw the image.
// To avoid the image to be draw outside the screen,
// take into account the image size.
int x = random(TFTscreen.width() - logo.width());
int y = random(TFTscreen.height() - logo.height());
// draw the image to the screen
TFTscreen.image(logo, x, y);
// wait a little bit before drawing again
delay(1500);
but there is a problem using more than 3 variables with the TFTscreen part.
Working sample code with my pin configuration (Arduino UNO):
//Taken from http://arduino.cc/en/Reference/TFTText
#include <SPI.h>
#include <TFT.h> // Arduino TFT library
#define SCLK 1
#define MOSI 7
#define CS 8
#define DC 9
#define RESET 12
Adafruit_ST7735 screen = Adafruit_ST7735(CS, DC, MOSI, SCLK, RESET);
// initialize the screen
//screen.begin(); begin() is only available when using TFT instead of Adafruit_ST7735
//so we have to use the next two lines instead.
screen.initR(INITR_REDTAB);
screen.setRotation(1);
// make the background black
screen.background(0,0,0);
// set the text color to white
screen.stroke(255,255,255);
// write text to the screen in the top left corner
screen.text("Testing!", 0, 0);
@Zaungast, I had the same issue with using the tft function with five paramaters. Your solution with two changes eliminated the error I faced. But now the TFT does not display the correct image that I have called from the SD. It shoes some random placed black bands and colour lines… what could have posiibly gone wrong with my program?
Im using arduino DUE and connecting a TFT 160X128 pixels through software SPI. here is my code.
#include <SPI.h>
#include <SD.h>
// pin definition for the Due
#define sd_cs 7
#define lcd_cs 4 //before, the value was 10,52,
#define dc 9
#define rst 8
#define sclk 12 //using other pins instead of hardware SPI pins
#define mosi 11 //using other pins instead of hardware SPI pins
//miso is on pin 5
//TFT TFTscreen = TFT(lcd_cs, dc, mosi, sclk, rst);
Adafruit_ST7735 TFTscreen = Adafruit_ST7735(lcd_cs, dc, mosi, sclk, rst);
//TFT TFTscreen = TFT(lcd_cs, dc, rst);
PImage logo;
// TFTscreen.begin();
//begin() is only available when using TFT instead of Adafruit_ST7735
//TFTscreen.initB();
TFTscreen.initR(INITR_GREENTAB);
TFTscreen.setRotation(3);
TFTscreen.background(255, 0, 255);
TFTscreen.println(F("Arduino TFT Bitmap Example"));
TFTscreen.println(F("Open serial monitor"));
TFTscreen.println(F("to run the sketch"));
delay(1500);
while (!Serial) {
// wait for serial port to connect. Needed for native USB port only
Serial.print(F("Initializing SD card..."));
Serial.println(F("failed!"));
return;
Serial.println(F("OK!"));
// image file.
logo = TFTscreen.loadImage("4.bmp");//24 bit image stored in sd card
Serial.println(F("error while loading arduino.bmp"));
return;
Serial.println(F("drawing image"));
int x = (TFTscreen.width() - logo.width())/2;
int y = (TFTscreen.height() - logo.height())/2;
delay(1500);
