Arduino Leonardo - 96x64 OLED RGB (SSD1331) - Doesn't work after correct wiring
Hello!
I have problems with either my Arduino or my OLED screen because after using that tutorial:
I uploaded a program attached to that tutorial and nothing shows up.
I double checked my wiring if it is correct, I connected all wires exactly like in the tutorial.
PS. I am new to Arduino
The tutorial is for a Nano. If you make the connections shown on the Nano diagram but with a Leonardo it won't work because the SPI pins are not the same on the Leonardo. Refer to this page of the Arduino documentation to see the SPI pins on the Leonardo:
Is there a way to bypass the ICSP-4 and ICSP-3 pins?
Or atleast wire them so it would work with the screen?
What do you mean "bypass"?
Why do you want to do that?
Did you try wiring the screen to the equivalent ISP pins to the Nano pins, as shown on the chart in the link above? If so, did it work?
Okay, it works now.
That was actually the first thing I tried after finding that I should connect it to ICSP pins, but after first wiring it didn't work so I thought it cannot be that easy, and thats why I wanted to "bypass" the pins I was sure it doesn't work. But now I tried and it is okay, probably faulty wire.
Thank you very much.
