I am trying to make Intellivision controller adapters like these. The first one is based on the second one but updated a bit.
Intellivision Controller Adapter 1 And Intellivision Adapter 2
Everything works great if I use only digital pins. I wanted to put two controllers on one Arduino Micro. I need 16 inputs and ground. The Micro has 20 inputs (using analog). It should work. But if I use just 1 analog pin, this does not work. I am testing it with just one controller. If I use pins 2-9, it works fine. If I use 3-9 and A0 as pin 14, part of it doesn't work. It seems that if I use multiple analog pins, I get all kinds of ghost keys being pressed.
Could anyone tell me why it doesn't work when I use the analog inputs? Do you think the controllers can't pull the analog inputs to low maybe? Could I do it a different way with resistors or something? I know the first link has code for 2 controllers but he is using an MCP chip to make that happen (which I don't currently have). I would like to go without if possible. If not, I guess I will order one up.
I just figured I would try here first. Thanks for looking and for any help you can give.
J_K_M_A_N
