Arduino Leonardo and forcefeedback
Hi all
i'm trying to use an Arduino Leonardo as controller for my diy steering wheel with force feedback. I have changed HID descriptor in HID.cpp and USBAPI.h and now the arduino is recognized as joypad with all the buttons and axis i want. I have now the problem to make the arduino to be recognized as a force feedback capable device. I have also a fanatec and a logitech steering wheels and both add this keys in windows registry during driver installation :
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/MediaProperties/PrivateProperties/Joystick/OEM/VID_XXXX&PID_YYY/OemForceFeedback/Effects
( XXXX and YYYY are vendor and product id )
under effects are inserted some keys, that define the type of force ( contant value, ramp, square wave, sine wave, etc... ) the steering wheel can do. It's not a problem to write the code pwm of the motor to play ramp, square wave etc... , the problem is to make arduino recognized as ffb capable device and intercept this values. I have found this doc :
http://msdn.microsoft.com/en-us/library/windows/hardware/ff542434%28v=vs.85%29.aspx
but programming under windows is beyond my limits. For the first problem is enough to write correct keys in registry ?
Someone with more skills than me can explain how it can be done ? Thank you !
Did you managed it? Having the same problem atm :)
