I am trying to program a script to an atmega328P but keep failing, because of that: "Device signature = 0x000000"
I connected the ATMega328P like this:
(https://www.bitfoic.com/upload/20231213/25844c0c0e8684550735d6f25012063d.jpg)
(https://content.arduino.cc/assets/Pinout-Leonardo_latest.pdf)
ATMega --- Arduino Leonardo
PIN 7 ----- Arduino leonardo digital pin 5V
PIN 20 --- Arduino Leonardo Digital pin 5v (the same as above)
PIN 8 ----- Arduino leonardo Digital Pin GND
PIN 22 --- Arduino Leonardo Digital Pin GND (the same as above)
PIN 1 ----- Arduino Leonardo Digital Pin 10
PIN 17 --- Arduino Leonardo ISCP 4 (bottom)
PIN 18 --- Arduino Leonardo ICSP 1 (top right)
PIN 19 --- Arduino Leonardo ICSP 3 (top)
And I also connected a 10 uF condenser between RESET (long metal) and GND (short metal)
but it didn't help.
What i did:
I first opened the example Arduino as ISP sketch and changed the heartbeat to Pin 13, so I can see it. The reset pin was already changed to Pin 10 so i didn't had to do anything else
After that I uploaded it to the Leonardo - successfully
the L - Pin started a heartbeat.
Then I created a little sketch for the ATMega and after selecting tools -> Arduino Uno and tools -> Arduino as ICP (Leonardo - ME)
...\Arduino15\packages\arduino\hardware\leofix\programmers.txt
arduinoispleo.name=Arduino as ISP (Leonardo - ME)
arduinoispleo.communication=serial
arduinoispleo.protocol=arduino
arduinoispleo.speed=19200
program.tool=avrdude
and pressing burn bootloader, because I just bought the Atmega, that error came into the console:
C:\Users\mirek\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\mirek\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\mirek\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
Fehler beim Brennen des Bootloaders.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
0x00000 means that the ATMega doesn't responses, but i tripple checked every connection and even connected it to the ICSP header of the Leonardo, but it didn't work. Even without burning the bootloader and just Uploading using programmer, the same error occurs.
