Arduino Leonardo connector specifications
Hi, What is the name/specifications of the USB connector that Arduino Leonardo uses? I tried to Google it up but found no satisfying results.
http://arduino.cc/en/Main/ArduinoBoardLeonardo
The Arduino Leonardo is a microcontroller board based on the ATmega32u4 (datasheet). It has 20 digital input/output pins (of which 7 can be used as PWM outputs and 12 as analog inputs), a 16 MHz crystal oscillator, [u]a micro USB connection[/u], a power jack, an ICSP header, and a reset button
Thanks, but I found what I needed at http://en.wikipedia.org/wiki/USB#Host_and_Device_interface_receptacles. :)
