Arduino Leonardo Crashing after hours of running with I2C LCD
Something seems to be locking up my hot tub control code one Leonardo with an ATmega32. I think that interference may be causing it since it doesn't happen on every board, just two at this point. I have a theory that the screen updating new info is somehow hanging up the firmware but I don't know how to fix it. Here is the code.
#include <Wire.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 20, 4);
// Defining pins------------------------
// Inputs ********************
#define Button1       5
#define Button2       10
#define Button3       9
#define TempSensor    A5
#define Flow_SW       A4
// Outputs *******************
#define HeatRealy_1   12
#define HeatRealy_2   8
#define OzoneRealy    11
#define ValveRealy    1
#define JetPump_Low   4
#define JetPump_High  0
#define PowerLed      13
// Different States:
int jets_State   = 0;      // 0 = OFF, 1 = LOW, 2 = HIGH
String jetsState = "OFF";
String prevJetsState = "OFF";
bool jets_Low    = false;
String heatState = "OFF";
String prevHeatState = "OFF";
int ozoneState   = HIGH;   // Starting default state of Ozone
// Variables to store last update times:
unsigned long prevTempUpdate   = 0;
unsigned long lastOzoneUpdate  = 0;
unsigned long lastButtonPress1 = 0;
unsigned long lastButtonPress2 = 0;
unsigned long lastButtonPress3 = 0;
unsigned long jetsStartMillis  = 0;
unsigned long prevLcdUpdate    = 0;
// Time variables (changeable):
unsigned long airPurgeTime  = 30000;    // Turn ON Jets Low for this amount of time at startup
unsigned long tempInterval  = 20000;    // How long to wait before taking a new temperature reading
unsigned long ozoneInterval = 10800000; // 3 hrs * 3600 seconds on/off cycle
unsigned long jetsTimeout   = 1800000;  // 30 min, How long it takes jets to turn OFF after starting
unsigned long lcdUpdateInt  = 30000;  // 20 min, The whole display updates after this time
// Other variables Set (changeable):
int set_Temp = 100;      // Deg F
int current_Temp = 105;
int minTemp = 52;    // Min temp that can be set
int maxTemp = 104;   // Max temp that can be set
int maxTempReadings = 20;  // How many temp readings to take at a time to average
float Vout = 0.0, Sens_Res = 0.0, avg_Res = 0.0;
  //Serial.begin(9600);
  // INPUTS
  pinMode(Button1, INPUT_PULLUP);
  pinMode(Button2, INPUT_PULLUP);
  pinMode(Button3, INPUT_PULLUP);
  pinMode(Flow_SW, INPUT_PULLUP);
  // OUTPUTS
  pinMode(HeatRealy_1, OUTPUT);
  pinMode(HeatRealy_2, OUTPUT);
  pinMode(OzoneRealy, OUTPUT);
  pinMode(ValveRealy, OUTPUT);
  pinMode(JetPump_Low, OUTPUT);
  pinMode(JetPump_High, OUTPUT);
  pinMode(PowerLed, OUTPUT);
  // Setting Outputs initially
  digitalWrite(HeatRealy_1, LOW);
  digitalWrite(HeatRealy_2, LOW);
  digitalWrite(OzoneRealy, LOW);
  digitalWrite(ValveRealy, LOW);
  digitalWrite(JetPump_Low, LOW);
  digitalWrite(JetPump_High, LOW);
  digitalWrite(PowerLed, HIGH);  // Turn ON at startup
  // Initialize LCD Display
  Wire.setWireTimeout();
  lcd.init();
  lcd.backlight();
  lcd.clear();
  // Line 0
  lcd.setCursor(0, 0);
  lcd.print("SYSTEM STARTING");
  // Line 1
  lcd.setCursor(0, 1);
  lcd.print("Set Temp: ");
  lcd.setCursor(10, 1);
  lcd.print(set_Temp);
  // Line 2
  lcd.setCursor(0, 2);
  lcd.print("Jets: ");
  lcd.setCursor(6, 2);
  lcd.print("START");
  // Line 3
  lcd.setCursor(0, 3);
  lcd.print("Heat: ");
  lcd.setCursor(6, 3);
  lcd.print(heatState);
  Serial.println("Electric w/ Jets  Code Running");
  delay(2000);
  // Turn ON jets on LOW at startup for a set time
  digitalWrite(JetPump_Low, HIGH);
  delay(airPurgeTime);
  jetsState = "OFF";
  // Line 0
  lcd.print("                    ");
  lcd.print("Current Temp: ");
  // Line 2
  lcd.print("         ");
  lcd.print(jetsState);
  digitalWrite(OzoneRealy, ozoneState);  // Turn ON Ozone after startup
  lastOzoneUpdate = millis();            // Save the time ozone relay was turned ON
    Temperature Sensor Function-----------------------------------------------
  takeTempReading();  // Take a new temperature reading from the sensor
    Ozone Function------------------------------------------------------------
  // Check if its time to change the state of the Ozone Relay:
  if (millis() - lastOzoneUpdate >= ozoneInterval) {
    ozoneState = !ozoneState;   // Toggle the state, ON if OFF and vice versa
  if (digitalRead(JetPump_High) == HIGH) {  // If jets are high, turn Ozone OFF
    digitalWrite(OzoneRealy, LOW);  // Turn OFF
    Button 1 Function-----------------------------------------------------------
  if (digitalRead(Button1) == LOW) {  // If button 1 pressed, decrease set temp
    if (millis() - lastButtonPress1 > 50) {
      Serial.println("Button 1 pressed!");
      set_Temp--;
      if (set_Temp < minTemp) {
        set_Temp = minTemp;
      displayLcd(1);  // Update line 1 on LCD display
    lastButtonPress1 = millis();
    Button 2 Function------------------------------------------------------------
  if (digitalRead(Button2) == LOW) {  // If button 2 pressed, Increase set temp
    if (millis() - lastButtonPress2 > 50) {
      Serial.println("Button 2 pressed!");
      set_Temp++;
      if (set_Temp > maxTemp) {
        set_Temp = maxTemp;
      displayLcd(1);// Update line 1 on LCD display
    lastButtonPress2 = millis();
    Button 3 Function------------------------------------------------------------
  if (digitalRead(Button3) == LOW) {  // If button 3 pressed
    if (millis() - lastButtonPress3 > 50) {
      Serial.println("Button 3 pressed!");
      if (digitalRead(HeatRealy_1) == LOW) {  // If heating is turned OFF
        jets_State++;
        if (jets_State == 1) {
          jetsState = "LOW";
          jetsStartMillis = millis();  // Save the Start time when jets were set to LOW
        else if (jets_State == 2) {
          jetsState = "HIGH";
          jetsStartMillis = millis();  // Save the Start time when jets were set to HIGH
        else if (jets_State > 2) {
          jets_State = 0;   // Reset and go back to OFF
          jetsState = "OFF";
      else {  // If heating is turned ON, toggle between LOW and HIGH
          jets_State = 2;
          jetsState = "HIGH";
        else {
          jets_State = 1;
          jetsState = "LOW";
      displayLcd(2);
      delay(50);// Update line 2 on LCD display
    lastButtonPress3 = millis();
    Heater Function---------------------------------------------------------------
  if (current_Temp < set_Temp) {  // If temperaure is less than the set temp, turn ON Heaters
    digitalWrite(HeatRealy_1, HIGH);
    digitalWrite(HeatRealy_2, HIGH);
    heatState = "ON";
    if (jets_State == 0) {
      jets_Low = true;   // Turn ON Jets at low speed
  else if (current_Temp >= set_Temp + 1) {  // If current temperaure is 1 deg greater than the set temp, turn OFF Heaters
    heatState = "OFF";
    jets_Low = false;
  else{
      // do nothing
  if (digitalRead(JetPump_Low) == HIGH || digitalRead(JetPump_High) == HIGH) {  // Check only if jets are ON
    if (digitalRead(Flow_SW) == HIGH) {  // If Flow sensor reads HIGH = 1, Turn OFF heater
      heatState = "LOW FLOW";
      jets_Low = true;
  if (prevHeatState != heatState) {  // Update on display if state changed
    prevHeatState = heatState;
    displayLcd(3);
    delay(50);// Update line 3 on LCD display
    Jets Function----------------------------------------------------------------------
  if (jets_Low == true && jets_State == 0) {  // Turn jets ON if heater is ON and jets were OFF
    jetsState = "LOW";
  else if (jets_State == 1) {  // Turn jets LOW if set to 1
    jetsState = "LOW";
  else if (jets_State == 2) {  // Turn jets HIGH if set to 2
    digitalWrite(JetPump_High, HIGH);
    jetsState = "HIGH";
  else {  // Turn jets OFF if set to 0
    jetsState = "OFF";
  if (digitalRead(HeatRealy_1) == LOW) {  // Check only if Heating is OFF
    if (digitalRead(JetPump_Low) == HIGH || digitalRead(JetPump_High) == HIGH) {  // If Jets are HIGH or LOW
      if (millis() - jetsStartMillis >= jetsTimeout) {  // Check for timeout
        jets_State = 0;  // Turn OFF jets after timeout
  if (prevJetsState != jetsState) {  // Update on display if jets state changed
    prevJetsState = jetsState;
    displayLcd(2);
    LCD display Function-------------------------------------------------------------
   if (millis() - prevLcdUpdate >= lcdUpdateInt) {  // Update the LCD display every 5 sec
    prevLcdUpdate = millis();
    lcd.clear();
    delay(50);
    displayLcd(0);
    delay(50);
    displayLcd(1);
    delay(50);
    displayLcd(2);
    delay(50);
    displayLcd(3);// Update all 4 lines
void displayLcd(int lineNo) {
  String currTemp = "";
  if (current_Temp < 53) {
    currTemp = "COLD";
  else if (current_Temp > 111) {
    currTemp = "HOT";
  else {
    currTemp = String(current_Temp);
  String line0 = "Current Temp: " + currTemp;
  String line1 = "Set Temp: " + String(set_Temp);
  String line2 = "Jets: " + jetsState;
  String line3 = "Heat: " + heatState;
  if (lineNo == 0) {
    lcd.setCursor(14, 0);
    lcd.print("    ");
    lcd.print(line0);
  else if (lineNo == 1) {
    lcd.print("    ");
    lcd.print(line1);
  else if (lineNo == 2) {
    lcd.print("    ");
    lcd.print(line2);
  else if (lineNo == 3) {
    lcd.print("        ");
    lcd.print(line3);
  else {
    lcd.print(line0);
    lcd.print(line1);
    lcd.print(line2);
    lcd.print(line3);
void takeTempReading() {
  if (millis() - prevTempUpdate >= tempInterval) {
    avg_Res = 0;
    for (int i = 0; i < maxTempReadings; i++) {
      Vout = analogRead(TempSensor);
      Vout = Vout * 0.004883;
      Sens_Res = (Vout * 10000) / (5 - Vout);
      avg_Res = avg_Res + Sens_Res;
      delay(10);
    Sens_Res = (avg_Res / 20);
    Serial.print(Sens_Res);
    Serial.print("   ");
    Res_Temp_Chart();
    Serial.println(current_Temp);
    lcd.print("      ");
    lcd.print(current_Temp);
    prevTempUpdate = millis();
    displayLcd(0);  // Update line 0 on LCD display
void Res_Temp_Chart() {
  if (Sens_Res > 55880)
    current_Temp = 50;  // Temperature LOW
  else if (Sens_Res < 55880 && Sens_Res > 53071)
    current_Temp = 53;
  else if (Sens_Res < 54455 && Sens_Res > 51726)
    current_Temp = 54;
  else if (Sens_Res < 53071 && Sens_Res > 50419)
    current_Temp = 55;
  else if (Sens_Res < 51726 && Sens_Res > 49149)
    current_Temp = 56;
  else if (Sens_Res < 50419 && Sens_Res > 47915)
    current_Temp = 57;
  else if (Sens_Res < 49149 && Sens_Res > 46716)
    current_Temp = 58;
  else if (Sens_Res < 47915 && Sens_Res > 45550)
    current_Temp = 59;
  else if (Sens_Res < 46716 && Sens_Res > 44418)
    current_Temp = 60;
  else if (Sens_Res < 45550 && Sens_Res > 43316)
    current_Temp = 61;
  else if (Sens_Res < 44418 && Sens_Res > 42245)
    current_Temp = 62;
  else if (Sens_Res < 43316 && Sens_Res > 41204)
    current_Temp = 63;
  else if (Sens_Res < 42245 && Sens_Res > 40192)
    current_Temp = 64;
  else if (Sens_Res < 41204 && Sens_Res > 39208)
    current_Temp = 65;
  else if (Sens_Res < 40192 && Sens_Res > 38251)
    current_Temp = 66;
  else if (Sens_Res < 39208 && Sens_Res > 37320)
    current_Temp = 67;
  else if (Sens_Res < 38251 && Sens_Res > 36414)
    current_Temp = 68;
  else if (Sens_Res < 37320 && Sens_Res > 35533)
    current_Temp = 69;
  else if (Sens_Res < 36414 && Sens_Res > 34676)
    current_Temp = 70;
  else if (Sens_Res < 35533 && Sens_Res > 33843)
    current_Temp = 71;
  else if (Sens_Res < 34676 && Sens_Res > 33032)
    current_Temp = 72;
  else if (Sens_Res < 33843 && Sens_Res > 32242)
    current_Temp = 73;
  else if (Sens_Res < 33032 && Sens_Res > 31474)
    current_Temp = 74;
  else if (Sens_Res < 32242 && Sens_Res > 30727)
    current_Temp = 75;
  else if (Sens_Res < 31474 && Sens_Res > 30000)
    current_Temp = 76;
  else if (Sens_Res < 30727 && Sens_Res > 29291)
    current_Temp = 77;
  else if (Sens_Res < 30000 && Sens_Res > 28602)
    current_Temp = 78;
  else if (Sens_Res < 29291 && Sens_Res > 27931)
    current_Temp = 79;
  else if (Sens_Res < 28602 && Sens_Res > 27278)
    current_Temp = 80;
  else if (Sens_Res < 27931 && Sens_Res > 26642)
    current_Temp = 81;
  else if (Sens_Res < 27278 && Sens_Res > 26023)
    current_Temp = 82;
  else if (Sens_Res < 26642 && Sens_Res > 25420)
    current_Temp = 83;
  else if (Sens_Res < 26023 && Sens_Res > 24832)
    current_Temp = 84;
  else if (Sens_Res < 25420 && Sens_Res > 24260)
    current_Temp = 85;
  else if (Sens_Res < 24832 && Sens_Res > 23703)
    current_Temp = 86;
  else if (Sens_Res < 24260 && Sens_Res > 23160)
    current_Temp = 87;
  else if (Sens_Res < 23703 && Sens_Res > 22632)
    current_Temp = 88;
  else if (Sens_Res < 23160 && Sens_Res > 22117)
    current_Temp = 89;
  else if (Sens_Res < 22632 && Sens_Res > 21615)
    current_Temp = 90;
  else if (Sens_Res < 22117 && Sens_Res > 21126)
    current_Temp = 91;
  else if (Sens_Res < 21615 && Sens_Res > 20649)
    current_Temp = 92;
  else if (Sens_Res < 21126 && Sens_Res > 20185)
    current_Temp = 93;
  else if (Sens_Res < 20649 && Sens_Res > 19733)
    current_Temp = 94;
  else if (Sens_Res < 20185 && Sens_Res > 19292)
    current_Temp = 95;
  else if (Sens_Res < 19733 && Sens_Res > 18862)
    current_Temp = 96;
  else if (Sens_Res < 19292 && Sens_Res > 18443)
    current_Temp = 97;
  else if (Sens_Res < 18862 && Sens_Res > 18034)
    current_Temp = 98;
  else if (Sens_Res < 18443 && Sens_Res > 19733)
    current_Temp = 99;
  else if (Sens_Res < 18034 && Sens_Res > 17247)
    current_Temp = 100;
  else if (Sens_Res < 19733 && Sens_Res > 16869)
    current_Temp = 101;
  else if (Sens_Res < 17247 && Sens_Res > 18443)
    current_Temp = 102;
  else if (Sens_Res < 16869 && Sens_Res > 16139)
    current_Temp = 103;
  else if (Sens_Res < 18443 && Sens_Res > 15788)
    current_Temp = 104;
  else if (Sens_Res < 16139 && Sens_Res > 15446)
    current_Temp = 105;
  else if (Sens_Res < 15788 && Sens_Res > 15112)
    current_Temp = 106;
  else if (Sens_Res < 15446 && Sens_Res > 14786)
    current_Temp = 107;
  else if (Sens_Res < 15112 && Sens_Res > 14468)
    current_Temp = 108;
  else if (Sens_Res < 14786 && Sens_Res > 14158)
    current_Temp = 109;
  else if (Sens_Res < 14468 && Sens_Res > 13855)
    current_Temp = 110;
  else if (Sens_Res < 14158 && Sens_Res > 13589)
    current_Temp = 111;
  else if (Sens_Res < 13589)
    current_Temp = 112;
    current_Temp = 120;  // Temperature HIGH
Your >/< sens_res bounds are overlapping.
Also... you "commented-out" Serial.begin() but then sent data to the Serial Monitor.
And... why not put the "Functions" in their own functions (they seem to all use global variables).
#include <Wire.h>
#define Button1       5
#define Button2       10
#define Button3       9
#define Flow_SW       A4
#define PowerLed      13
  Serial.begin(9600); // this was commented out... removed the comment-out
  // INPUTS
  // OUTPUTS
  lcd.init();
  lcd.backlight();
  lcd.clear();
  // Line 0
  // Line 1
  // Line 2
  lcd.print("START");
  // Line 3
  delay(2000);
  jetsState = "OFF";
  // Line 0
  lcd.print("                    ");
  // Line 2
  lcd.print("         ");
  Ozone();
  Button_1();
  Button_2();
  Button_3();
  Heater();
  Jets();
  LCDdisplay();
void Ozone()
void Button_1()
      set_Temp--;
        set_Temp = minTemp;
void Button_2()
      set_Temp++;
        set_Temp = maxTemp;
void Button_3()
        jets_State++;
          jetsState = "LOW";
          jetsState = "HIGH";
          jetsState = "OFF";
          jets_State = 2;
          jetsState = "HIGH";
        else {
          jets_State = 1;
          jetsState = "LOW";
      displayLcd(2);
void Heater()
    heatState = "ON";
    heatState = "OFF";
    jets_Low = false;
  else {
    // do nothing
      jets_Low = true;
    displayLcd(3);
void Jets()
    jetsState = "LOW";
    jetsState = "LOW";
    jetsState = "HIGH";
    jetsState = "OFF";
    displayLcd(2);
void LCDdisplay()
    lcd.clear();
    delay(50);
    displayLcd(0);
    delay(50);
    displayLcd(1);
    delay(50);
    displayLcd(2);
    delay(50);
    currTemp = "COLD";
    currTemp = "HOT";
  else {
  if (lineNo == 0) {
    lcd.print("    ");
    lcd.print(line0);
    lcd.print("    ");
    lcd.print(line1);
    lcd.print("    ");
    lcd.print(line2);
    lcd.print("        ");
    lcd.print(line3);
  else {
    lcd.print(line0);
    lcd.print(line1);
    lcd.print(line2);
    lcd.print(line3);
    avg_Res = 0;
      delay(10);
    Serial.print("   ");
    Res_Temp_Chart();
    lcd.print("      ");
    current_Temp = 53;
    current_Temp = 54;
    current_Temp = 55;
    current_Temp = 56;
    current_Temp = 57;
    current_Temp = 58;
    current_Temp = 59;
    current_Temp = 60;
    current_Temp = 61;
    current_Temp = 62;
    current_Temp = 63;
    current_Temp = 64;
    current_Temp = 65;
    current_Temp = 66;
    current_Temp = 67;
    current_Temp = 68;
    current_Temp = 69;
    current_Temp = 70;
    current_Temp = 71;
    current_Temp = 72;
    current_Temp = 73;
    current_Temp = 74;
    current_Temp = 75;
    current_Temp = 76;
    current_Temp = 77;
    current_Temp = 78;
    current_Temp = 79;
    current_Temp = 80;
    current_Temp = 81;
    current_Temp = 82;
    current_Temp = 83;
    current_Temp = 84;
    current_Temp = 85;
    current_Temp = 86;
    current_Temp = 87;
    current_Temp = 88;
    current_Temp = 89;
    current_Temp = 90;
    current_Temp = 91;
    current_Temp = 92;
    current_Temp = 93;
    current_Temp = 94;
    current_Temp = 95;
    current_Temp = 96;
    current_Temp = 97;
    current_Temp = 98;
    current_Temp = 99;
    current_Temp = 100;
    current_Temp = 101;
    current_Temp = 102;
    current_Temp = 103;
    current_Temp = 104;
    current_Temp = 105;
    current_Temp = 106;
    current_Temp = 107;
    current_Temp = 108;
    current_Temp = 109;
    current_Temp = 110;
    current_Temp = 111;
    current_Temp = 112;
To be completely honest I'm very new at this and paid someone to put this together originally (that's where the sens_res comes from) then paid someone else to put together this version. Of course after paying they have not help diagnose at all. I'm trying to learn how to make all this work on my own because it's fascinating and extremely useful.
Serial print stuff is from original version. I'll just comment out or delete it all.
Sens_res has had overlapping values since the beginning but the sensor seems to put out accurate and stable readings from the beginning so I haven't messed with it.
Not sure what you mean by making them their own functions. They have separate void loops already?
Although I'm probably not the one that can help, if you suspect interference, please provide a schematic diagram / wiring diagram. A photo of a handdrawn one is fine; it should contain all connections between components as well as ALL power/gnd connections. A photo of your setup might also help. Please provide product info about (preferably links to) all components that you use; don't forget motors/heaters etc.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the IDE 1.x category.
