Hello everybody. I have one problem with my new Arduino Leonardo ETH. Finally I want to flash the Firmata SW to connect some sensors to my FHEM. But the Arduino did not connect to the FHEM server. So flashed the Webserver.ino to check the hardware. Result was the same. I cannot connect by browser to the specified IP also no ping.
Then I tried the same with an Mega 2560 with ethernet-shield and it works directly. Also the Firmata software runs at the 2560 and connected to the FHEM server.
Now the question, is there an hardware-problem at my Leonardo? When I connect the ethernet-cable to my ethernet-switch the LEDs 100M, LINK, FDX are on an the ACT-LED is blinking. The two LEDs at the ETH-connector are lit but not blinking.
There is also something I am wondering. When I select the board in the Arduino IDE 1.6.6, there is just the Arduino Leonardo. But I have the Arduino Leonardo ETH. Is there no difference?
Is there anybody who has an idea what’s wrong or what I can check? Here is my ethernet configuration:
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
OK, I think I found the problem.
Found at Arduino - Home
NB. You can reuse your code written for Arduino Ethernet Shield or Arduino Ethernet, simply replacing #include <Ethernet.h> --> #include <Ethernet2.h> #include <EthernetUdp.h> --> #include <EthernetUdp2.h>
OK Sorry,
it wasn't the solution. Now I use the EthernetUdp.h but the problem is still there . Any idea what’s wrong? The LEDs at the ETH connector are still on but nut blinking.
Greats,
Boris
Leonardo ETH uses the W5500 Ethernet controller chip. The Ethernet library (Ethernet.h, EthernetUdp.h) does not support W5500 so even though the sketch compiles it will not work. You need to install and use the Ethernet2 library:
Sketch > Include Library > Manage Libraries...
Wait for download to complete
In the "Filter your search..." box type "Ethernet2"
Click on "Ethernet2 by various".
Click "Install"
Wait for installation to complete
Click "Close"
Make sure any sketch you use with you Leonardo ETH uses the filenames Ethernet2.h or EthernetUdp2.h, not Ethernet.h or EthernetUdp.h
