Hi, I use a leonardo eth with motor shield to control a motor to get my new SUHD-TV up and down . I have attached a keypad 1-4 and two pushbuttons to check the final positions.
The sketch works only with the keypad, if I will access on the IP-adress to get access on the software-buttons (similar function as keypad 1-4) on the page, the arduino-homepage is not available. Ping works.
Code: [Select]
byte rowPins[rows] = {2, 10, 6, 5}; //connect to the row pinouts of the keypad 2:pink 10:gelb 6:braun 5:rot
You need to pay attention to which pins the Ethernet shield uses, and not try to re-use them.
I use the leonardo ethernet with motorshield V2, from the specs the pinns 2, 10, 6, 5 should be ok? Or I am wrong?Arduino - Home
TWI: 2 (SDA) and 3 (SCL): they support TWI communication using the Wire library.
External Interrupts: 3 (interrupt 0), 2 (interrupt 1), 0 (interrupt 2), 1 (interrupt 3) and 7 (interrupt 4). These pins can be configured to trigger an interrupt on a low value, a rising or falling edge, or a change in value. See the attachInterrupt() function for details.
PWM: 3, 5, 6, 9, 10, 11 and 13. Provide 8-bit PWM output with the analogWrite() function.
