Arduino Leonardo - Mouse Library Error
Hello!
I am currently working on a project that entails using a Arduino as a mouse. In the code posted, I am trying to get the cursor of the mouse to move when a certain keyboard button is pressed by reading inputs from the serial monitor.
For this project I am using the Arduino Leonardo (which after a bit of research saw is compatible with the Arduino mouse library).
My code will not compile, I am receiving the following error message:
error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
    Mouse.end();
Multiple libraries were found for "Mouse.h"
The code I have written is below. I have included the header file, so I am a bit confused on why I keep getting this problem. Any help is appreciated, thanks!
P.S. Haven't had a chance to debug the rest of the code yet (stuck on the dang header file problem), so there might be other errors that I haven't picked up on yet.
#include <Mouse.h>
  Mouse.begin();
  if(Serial.available()){
    direction = Serial.read();
   if(direction == 'w'){
      Mouse.move(0, 10, 0);
   else if(direction == 'd'){
    Mouse.move(10, 0, 0);
   else if(direction == 's'){
    Mouse.move(0, -10, 0);
   else if(direction == 'a'){
    Mouse.move(-10, 0, 0);
   else if(direction == 'h'){
    Mouse.move(0, 0, 10);
   else if(direction == 'j'){
    Mouse.move(0, 0, -10);
   else if(direction == 'k'){
    Mouse.click();
   else if(direction == 'L'){
    Mouse.click(MOUSE_RIGHT);
   else if(direction == 'E'){
   Mouse.end();
Are you compiling for the correct board? You will need to select the Leonardo in tools -> boards.
The mouse library is part of the IDE. Did you manually install another one? The 'multiple libraries found' message is usually not something to worry about unless it picks the wrong one.
