Arduino Leonardo No Longer Recognized by Windows
To preface this, I am fairly new to Arduino and its software. I'll try to be as thorough as possible.
I have an Arduino Leonardo which my Windows computer no longer recognizes. Whenever I plug it into the USB port, Windows simply says that it couldn't recognize the device. When I try to set the COM port which the board is plugged into in the Arduino IDE, the tab is greyed out and I can't select anything (I'm on Windows 10 and the latest version of the Arduino IDE).
The board worked just fine until I attempted to upload an empty program so that it wouldn't instantly run something when connected to a power source. I believe the code had an exit(0) in the setup, but uploading seems to have made the Arduino unrecognizable? The problem arises where I can, of course, no longer upload new code to the Leonardo.
I have tried using different cables, different USB ports, different computers (including a Mac), pushing the reset button and uploading at different intervals, etc. and yet I still cannot seem to get it working.
I additionally have an Arduino Uno, which I tried to use to send a new program to the Leonardo as an ISP, while following other forums posts (again I'm a beginner so please bear with me if what I'm doing is completely off the mark). While I'm fairly certain the connections were correct (13 -> 13, 12 -> 12, 11 -> 11, 10 -> Reset, Gnd -> Gnd, 5v -> 5v), and that I had selected "Arduino as ISP" and "Upload Using Programmer", it gives me this error:
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Other posts have something about potentially needing a capacitor wiring the Reset to the Gnd pin on the programmer, but I figured I'd ask here before having to buy capacitors. Any input on my problem would help, as I'm trying my best to not have to go out and just buy a new board. Thanks in advance.
AVRDude says, that the device signature is invalid. I think you have bricked the chip. Please tell us anything wrong done with the Leornado previously. This might be the problem. Any wrong connection, or overvoltage given to the board will cause such problems.
.. Arnav
