Hello, I need help on a recurrent bug.
I try to emulate WASD with a joystick connected to Arduino leonardo board.
Sometimes, when I reinstall Arduino IDE, Keyboard library functions work, and when I upload it several times (for improvement), these keyboard functions stop working while everything else keep working.
First time it disfunctionned, I reinstalled Arduino Uno and restarted windows 10, and magically the same program worked again. Then I uploaded a program for 2 joysticks and the simple joystick program messed again: no keyboard function.
And reinstalling Arduino IDE didn't change anything
Second time, it magically worked again, I had to restart windows 10 for update, uninstall Arduino IDE, restart Windows 10 again, install Arduino IDE.
And after upload the same program, keyboard function stop working again.
I am pretty sure the problem doesn't come from the hardware, my board is leonardo but not an original from Arduino.
I am also pretty sure the problem is not my code :
#include<Keyboard.h>
// Analog input of the horizontal joystick position
const int JoystickX = A0;
// Analog input of the vertical joystick position
const int JoystickY = A1;
//joystick press
const int SW_pin = 2;
pinMode(SW_pin, INPUT_PULLUP);
// Process horizontal joystick position
int x = analogRead(JoystickX);
if (1023 == x)
Keyboard.press('d');
Serial.print("eaezae");
else if (0 == x)
Keyboard.press('a');
Keyboard.release('d');
Keyboard.release('a');
delay(5);
// Process vertical joystick position
int y = analogRead(JoystickY);
if (0 == y)
Keyboard.press('w');
else if (1023 == y)
Keyboard.press('s');
Keyboard.release('w');
Keyboard.release('s');
delay(5);
int z = digitalRead(SW_pin);
Serial.print(z);
if(0==z)
Keyboard.press('e');
Keyboard.release('e');
I already tried to upload this program and the connect the arduino board at the exact moment linking everything together was displayed in the console but didn't work.
I also tried to change the port & com number in peripheral device but didn't work either
I am running out of idea
