Arduino Leonardo wiring
hi. i have build an hydraulic handbrake for car simracing. i got a 1000 psi pressure sender with 3 wires ( red,black and green)
i have try to wire it: red to 5v+ , black to gnd and green to analog but i dont get it to work.
have i done it right ? or do i need some more components?
Card: Arduino Leonardo
regard Lennart
Installation and Troubleshooting is for Problems with the Arduino IDE itself NOT your project. It says so in the description of the section.
Therefore I have moved your post here. Please be more careful where you post in future.
You may want to read this before you proceed:-
how to get the best out of this forum
Can you post your code, a schematic of how you have wired it up and a link to your pressure sensor. The colour wires don't tell you much without the data sheet. You are just making a guess, which is most likely wrong. But don't try other wire combinations because there is a chance you will damage your sensor.
What do you mean? What values are you getting from the analogRead()?
