Arduino Leonardo with HC-05
I am having some problem establishing communication between my PC and leonardo via bluetooth.
I understand that leonardo board using Serial1 instead of Serial class.
//Standard PWM DC control
int E1 = 5;     //M1 Speed Control
int E2 = 6;     //M2 Speed Control
int E3 = 11;    //M3 Speed Control
int M1 = 4;     //M1 Direction Control
int M2 = 7;     //M2 Direction Control
int M3 = 9;    //M3 Direction Control
void setup(void)
  int i;
  //for(i=4;i<=7;i++)
  Serial1.begin(9600);
  while (!Serial1)
    // do nothing
  Serial1.println("Run keyboard control");
void stop()                    //Stop
  digitalWrite(E1,LOW);
  digitalWrite(E2,LOW);
  digitalWrite(E3,LOW);
void advance(char a,char b,char c)          //Move forward
  analogWrite (E1,a);      //PWM Speed Control
  digitalWrite(M1,LOW);
  analogWrite (E2,b);
  digitalWrite(M2,LOW);
  analogWrite (E3,c);
  digitalWrite(M3,LOW);
void back_off (char a,char b,char c)          //Move backward
  analogWrite (E1,a);
  digitalWrite(M1,HIGH);
  analogWrite (E2,b);
  digitalWrite(M2,HIGH);
  analogWrite (E3,c);
void Left (char a,char b,char c)             //Move Left
  analogWrite (E1,a);
  analogWrite (E2,b);
  analogWrite (E3,c);
void Right (char a,char b,char c)             //Move Right
  analogWrite (E1,a);
  analogWrite (E2,b);
  analogWrite (E3,c);
  digitalWrite(M3,HIGH);
void Turn_R (char a,char b,char c)             //Rotate CW
  analogWrite (E1,a);
  analogWrite (E2,b);
  analogWrite (E3,c);
void Turn_L (char a,char b,char c)             //Rotate CCW
  analogWrite (E1,a);
  analogWrite (E2,b);
  analogWrite (E3,c);
  if(Serial1.available() > 0){
    //Serial.print("Hello");
    char val = Serial.read();
      switch(val)
      case 'w'://Move Forward
        advance (255,255,0);   //move forward in max speed
      case 's'://Move Backward
        back_off (255,255,0);   //move back in max speed
      case 'a'://Move Left
        Left (255, 255, 255);
      case 'd'://Move Right
        Right (255, 255, 255);
      case 'q'://Rotate CCW
        Turn_L (255, 255, 255);
      case 'e'://Rotate CW
        Turn_R (255, 255, 255);
      case 'z':
        Serial1.println("Hello");
      case 'x':
        stop();
While using USB wire, everything is work well when I input w,a,s,d
But when I connect through bluetooth COM port, nothing happened.
      switch(val)
Insted, as you connected the BT to serial1,
use
    char val = Serial1.read();
      switch(val)
Regards, -Malhar
Thank for you reply Malhar.
I have amended the code but somehow it still does not work as expected.
Was wondering if the Vin on the HC05 should be connected to the 5V or the 3V3 on the leonardo board? Does it matter to where it is connected?
Regards,
BK
