Recently I bought Arduino Leonardo Board and XBee Shield (v 2.2 seeed studio) and GPS Bee module (v1.3 seeed studio).
Now I'm trying to recive data and send commands. Reciving and parsing data is going fine, but when I'm trying to send some command to my shield it does not response in any way.
#include <SoftwareSerial.h>
#include <string.h>
#include <nmea.h>
SoftwareSerial SoftSerial(10,11);
NMEA gps(GPRMC);
delay(3000);
Serial1.begin(9600);
SoftSerial.begin(9600);
pinMode(11, OUTPUT);
pinMode(10, INPUT);
delay(3000);
SoftSerial.println("$PMTK300,500,0,0,0,0*28<CR><LF>");
delay(3000);
void loop(){
if (SoftSerial.available() > 0 ) {
// read incoming character from GPS and feed it to NMEA type object
if (gps.decode(SoftSerial.read())) {
// full sentence received
Serial.print ("Sentence = ");
Serial.println (gps.sentence());
Serial.print("Speed:");
Serial.println(gps.gprmc_speed(MPS));
Serial.print("Longtitude:");
Serial.println(gps.gprmc_longitude());
Serial.print("Latitude:");
Serial.println(gps.gprmc_latitude());
I guess there is some problem with RX and TX, but I'm not sure. I also tried to replace "SoftSerial.println" with "SoftSerial.write" and "" with "/r/n"
I also tried to exchange pints for 0,1 and use Serial1 instead of just Serial.
The string "" likely doesn't mean anything to the device. The println() method is already sending a carriage return and line feed, so just lose that part.
pinMode(10, INPUT);
You told the SoftwareSerial instance that these were its pins. Quit f**king with them.
I don't understand your problem. If you can receive data, from the GPS using the SoftwareSerial instance, but the GPS does not appear to recognize what you are sending it, the problem is with what you are sending it, not the failure to send it.
It is not clear what the XBee(s) have to do with anything.
I also tried to send without , but it didn't help
pinMode(10, INPUT);
This is not a problem, this is one of my tries to solve it. I read, that not every Leonardo pin supports RX, so I tried to make this pins work as input and output, It didnt help too
So my question is - If my code is wrong or I have to use some other pins or, maybe, some other suggestions. I'm pretty noob with arduino, so I may not see something obvious [/code]
Pins that don't work for SoftwareSerial are those that do not support pin change interrupts. Declaring a pin that does not support pin change interrupts OUTPUT won't make the hardware suddenly support pin change interrupts. Declaring a pin that does not support pin change interrupts INPUT won't make the hardware suddenly support pin change interrupts.
The only thing that might be wrong with your code is how it is sending information to the GPS. You have posted only a vague description of what GPS you have, so you can't expect us to know what you need to send it, or how to send it that.
What output do you see on the Serial Monitor application?
PaulS:
Hmm, well, my bad, it looks like obvious one now
PaulS:
Sorry, I guess I should do this form the very beggining:
Olright:
Well, this is my first goal, to send command to output data twice a second.
I found this command here
Yup, this is a checksum. I calculated it with formula, however, if I calculated wrong, there should be response from my board, that it recived command, but didin't understand it.
PaulS:
Could you try setting the refresh rate to 250 (4 times per second) using the values at that site, to see if the last value IS a checksum?
I can, but, as I mentioned before, it will be no any response, so it would be useless to try.
For now, I have an idea, but I have to do other work now, so, I will try it later
If the value on the end IS a checksum, and the value that you have is not the proper checksum for the data that you have, the entire request will be discarded.
I presume that the values given on the web site ARE valid, and that they have been proven to work. I know that that might not be a valid assumption, but it can't hurt to test that assumption.
The alternative is to just accept that the GPS will output what it wants when it wants at the speed that it wants. If that's fine with you, it doesn't bother me.
