arduino librairie
hello, I did my Arduino program to control RFID and I recorded a bookstore “SeeedRFID” then the time to check my program it tells me an error message related to my library so I put you my program and my error message below can you help me please ?
#include <SoftwareSerial.h>
#include <SeeedRFID.h>
#define RFID_RX_PIN 0
#define RFID_TX_PIN 1
SeeedRFID RFID(RFID_RX_PIN, RFID_TX_PIN);
Serial.println(" RFID Reader Check ");
pinMode(11, OUTPUT) ;
pinMode(10, OUTPUT) ;
if(RFID.isAvailable())
Serial.print("RFID card number: ");
Serial.println(RFID.cardNumber());
if ( RFID.cardNumber() == 2098445032)
digitalWrite(10,HIGH);
digitalWrite(11, LOW);
digitalWrite(11, HIGH);
digitalWrite(10,LOW);
In file included from Projet_RFID.ino:3:0:
C:\Users\FOURDRAIN1\Documents\Arduino\libraries\RFID_Library-master/SeeedRFID.h:88:10: error: ‘void SeeedRFID::listen()’ cannot be overloaded
void listen();
C:\Users\FOURDRAIN1\Documents\Arduino\libraries\RFID_Library-master/SeeedRFID.h:86:10: error: with ‘boolean SeeedRFID::listen()’
boolean listen();
Erreur lors de la compilation.
Overloaded versions of a function must have a different argument list. A different result type is not sufficient.
You can NOT do software serial on the hardware serial pins while doing hardware serial on the same pins.
