Arduino Libraries Help
I'm reading a guide about making libraries but when i compile i get this error:
sequenza_rgb:1: error: #include expects "FILENAME" or
#include RGB.h
exit status 1
Here is the RGB.cpp
#include RGB.h
RGB :: Color()
r = 0;
g = 0;
b = 0;
RGB :: Color(unsigned int _r, unsigned int _g, unsigned int _b)
r = _r;
g = _g;
b = _b;
analogWrite(11, _r);
analogWrite(10, _b);
analogWrite(9, _g);
Here is the RGB.h
#ifndef RGB_h
#define RGB_h
#include Arduino.h
class Color
public:
Color();
Color(unsigned int _r, unsigned int _g, unsigned int _b);
unsigned int r;
unsigned int g;
unsigned int b;
The error message indicates what the problem is:
You have to put the filename between <> or "".
If the library is in your libraries folder (where it should be) you should use <>
Seems pretty clear to me. An include file must be either:
 #include <RGB.h>
which causes the compiler to first look in the default libraries directory, or:
 #include "RGB.h"
which causes the compiler to first look in the current working directory and, if not found, look in the default libraries directory. Your code uses neither.
