Arduino libraries stopped working in Simulink?
I have been using an S-function for an LCD in Simulink, which includes the Arduino source and header files LiquidCrystal.h and LiquidCrystal.cpp. This S-function has been working perfectly, but today I began encountering errors and the model will not build. It appears that Matlab no longer recognizes the syntax in the source and header files? Not sure why this is happening, but I was trying to create another S-function using the Wire and MAG3110 libraries and encountered the same issue. Below is the super long error for the LCD model. Any advice?
In file included from ../lcd_wrapper.c:19:0:
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.h:45:1: error: unknown type name 'class'
 class LiquidCrystal : public Print {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.h:45:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
In file included from ../lcd_wrapper.c:20:0:
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:27:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 LiquidCrystal::LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:34:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 LiquidCrystal::LiquidCrystal(uint8_t rs, uint8_t enable,
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:41:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:47:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:53:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::init(uint8_t fourbitmode, uint8_t rs, uint8_t rw, uint8_t enable,
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:78:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:167:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::setRowOffsets(int row0, int row1, int row2, int row3)
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:176:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::clear()
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:182:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::home()
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:188:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::setCursor(uint8_t col, uint8_t row)
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:202:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::noDisplay() {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:206:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::display() {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:212:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::noCursor() {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:216:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::cursor() {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:222:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::noBlink() {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:226:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::blink() {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:232:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::scrollDisplayLeft(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:235:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::scrollDisplayRight(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:240:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::leftToRight(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:246:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::rightToLeft(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:252:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::autoscroll(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:258:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::noAutoscroll(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:265:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::createChar(uint8_t location, uint8_t charmap[]) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:275:26: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 inline void LiquidCrystal::command(uint8_t value) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:279:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 inline size_t LiquidCrystal::write(uint8_t value) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:287:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::send(uint8_t value, uint8_t mode) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:303:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::pulseEnable(void) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:312:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::write4bits(uint8_t value) {
C:/Users/slb0494/Desktop/LCD/LiquidCrystal.cpp:320:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
 void LiquidCrystal::write8bits(uint8_t value) {
../lcd_wrapper.c:22:1: error: unknown type name 'LiquidCrystal'
 LiquidCrystal lcd(12,11,5,4,3,2);
../lcd_wrapper.c:22:19: error: expected declaration specifiers or '...' before numeric constant
../lcd_wrapper.c:22:22: error: expected declaration specifiers or '...' before numeric constant
../lcd_wrapper.c:22:25: error: expected declaration specifiers or '...' before numeric constant
../lcd_wrapper.c:22:27: error: expected declaration specifiers or '...' before numeric constant
../lcd_wrapper.c:22:29: error: expected declaration specifiers or '...' before numeric constant
../lcd_wrapper.c:22:31: error: expected declaration specifiers or '...' before numeric constant
../lcd_wrapper.c: In function 'lcd_Outputs_wrapper':
../lcd_wrapper.c:53:5: error: 'lcd' undeclared (first use in this function)
     lcd.setCursor(0,1);
../lcd_wrapper.c:53:5: note: each undeclared identifier is reported only once for each function it appears in
../lcd_wrapper.c: In function 'lcd_Update_wrapper':
../lcd_wrapper.c:74:5: error: 'lcd' undeclared (first use in this function)
     lcd.begin(16,2);
gmake: *** [lcd_wrapper.o] Error 1
### Creating HTML report file Test_codegen_rpt.html
