Hello,
I'm a beginner Arduino user and would like some help writing code to expand the use of the Adafruit LED Arcade Button 1x4 STEMMA QT.
I'd like to use not only 4 buttons option but daisy chain an additional 1x4 STEMMA QT to the tail end of the original. My understanding is that a new 1x4 STEMMA QT board would have a new "name" in the code different from the original "DEFAULT_I2C_ADDR 0x3A" and the "names" of the button inputs would also be different.
I'm unsure of where to insert these new lines of code into the Adafruit Library supplied example.
Any help is appreciated! Thanks for reading my question.
The Library code copy for the 1x4 STEMMA QT breakout is below:
* This example shows how read arcade buttons and PWM the LEDs on the Adafruit Arcade QT!
#include "Adafruit_seesaw.h"
#include <seesaw_neopixel.h>
#define DEFAULT_I2C_ADDR 0x3A
#define SWITCH1 18 // PA01
#define SWITCH2 19 // PA02
#define SWITCH3 20 // PA03
#define SWITCH4 2 // PA06
#define PWM1 12 // PC00
#define PWM2 13 // PC01
#define PWM3 0 // PA04
#define PWM4 1 // PA05
Adafruit_seesaw ss;
while (!Serial) delay(10); // wait until serial port is opened
Serial.println(F("Adafruit PID 5296 I2C QT 4x LED Arcade Buttons test!"));
if (!ss.begin(DEFAULT_I2C_ADDR)) {
Serial.println(F("seesaw not found!"));
while(1) delay(10);
uint16_t pid;
uint8_t year, mon, day;
ss.getProdDatecode(&pid, &year, &mon, &day);
Serial.print("seesaw found PID: ");
Serial.print(pid);
Serial.print(" datecode: ");
Serial.print(2000+year); Serial.print("/");
Serial.print(mon); Serial.print("/");
Serial.println(day);
if (pid != 5296) {
Serial.println(F("Wrong seesaw PID"));
while (1) delay(10);
Serial.println(F("seesaw started OK!"));
ss.pinMode(SWITCH1, INPUT_PULLUP);
ss.pinMode(SWITCH2, INPUT_PULLUP);
ss.pinMode(SWITCH3, INPUT_PULLUP);
ss.pinMode(SWITCH4, INPUT_PULLUP);
ss.analogWrite(PWM1, 127);
ss.analogWrite(PWM2, 127);
ss.analogWrite(PWM3, 127);
ss.analogWrite(PWM4, 127);
uint8_t incr = 0;
if (! ss.digitalRead(SWITCH1)) {
Serial.println("Switch 1 pressed");
ss.analogWrite(PWM1, incr);
incr += 5;
ss.analogWrite(PWM1, 0);
if (! ss.digitalRead(SWITCH2)) {
Serial.println("Switch 2 pressed");
ss.analogWrite(PWM2, incr);
incr += 5;
ss.analogWrite(PWM2, 0);
if (! ss.digitalRead(SWITCH3)) {
Serial.println("Switch 3 pressed");
ss.analogWrite(PWM3, incr);
incr += 5;
ss.analogWrite(PWM3, 0);
if (! ss.digitalRead(SWITCH4)) {
Serial.println("Switch 4 pressed");
ss.analogWrite(PWM4, incr);
incr += 5;
ss.analogWrite(PWM4, 0);
delay(10);
