Hello ,
I wonder if there is attachinterrupt() for Arduino Library in Processing.
because when i looked into this link Arduino Playground - HomePage
i found only few function for arduino library.
Thanks,
Hello ,
Thanks,
Code: [Select]attachinterrupt()
How could there be? The interrupt happens on the Arduino end, not on the Processing end.
The code to deal with an interrupt needs to run on the Arduino, which won't happen when you've lobotomized it by loading a Firmata sketch.
There are, of course, other ways to make the Arduino and Processing communicate. Which end should be the master and which end should be the slave defines what the code on each end should look like.
Firmata makes the Arduino a slave. Anything requiring interrupts means that the Arduino should be the master.
Not agree, in general the Arduino can be used as a preprocessing slave, some examples:
In short one can add an Arduino slave as intelligent front end to (a collection of) dumb sensors (interrupt driven or not).
e.g. an Arduino as I2C slave that monitors a temp sensor and humidity sensor and can return those, but also the average, max and minimum or the humidex. The Arduino can also filter out faulty reads, count these errors and gives an uptime of the dumb sensor.
Certainly. But not by installing Firmata.
thanks for your feedbacks
