so making a line following robot need help problem is when i add calibration the robot moves side to side alot?
#define sensorLeft 0
#define sensorRight 1
#define pwmr 11
#define pwml 10
#define right1 5
#define right0 6
#define left1 3
#define left0 4
int difference = 0;
int sensorValLeft = 0;
int sensorMinLeft = 1023;
int sensorMaxLeft = 0;
int sensorValRight = 0;
int sensorMinRight = 1023;
int sensorMaxRight = 0;
int ldrrval;
int ldrlval;
int diffldrl;
int diffldrr;
//Motor setup
pinMode(sensorLeft, INPUT);
pinMode(sensorRight, INPUT);
pinMode(pwml, OUTPUT);//Pins on the Arduino
pinMode(pwmr, OUTPUT);
pinMode(right1, OUTPUT);
pinMode(right0, OUTPUT);
pinMode(left1, OUTPUT);
pinMode(left0, OUTPUT);
//Calibration for both sensors in first 5 seconds
while(millis() < 5000)
sensorValLeft = analogRead(sensorLeft);
sensorValRight = analogRead(sensorRight);
//Records the maximum sensor value for the left
if(sensorValLeft > sensorMaxLeft)
sensorMaxLeft = sensorValLeft;
//Records the maximum sensor value for the right
if(sensorValRight > sensorMaxRight)
sensorMaxRight = sensorValRight;
//Records the minimum sensor value for the left
if(sensorValLeft < sensorMinLeft)
sensorMinLeft = sensorValLeft;
//Records the minimum sensor value for the right
if(sensorValRight < sensorMinRight)
sensorMinRight = sensorValRight;
void forward()
analogWrite(pwmr,100);
analogWrite(pwml,100);
digitalWrite(right1,HIGH);
digitalWrite(right0,LOW);
digitalWrite(left1,LOW);
digitalWrite(left0,HIGH);
void stop1()
digitalWrite(right1,LOW);
digitalWrite(left0,LOW);
void right()
analogWrite(pwmr,100);//(Output, Power for Motor)
analogWrite(pwml,30);
void left()
analogWrite(pwmr,30);
//Reads the light sensors
ldrlval = analogRead(sensorLeft);
ldrrval = analogRead(sensorRight);
diffldrl= sensorValLeft-ldrlval;
diffldrr =sensorValRight-ldrrval;
difference = diffldrl -diffldrr;
if(difference > -10 && difference < 10)
forward();
else if (difference > 10)
right();
delay(1);
stop1();
else if (difference < -10)
left();
delay(1);
stop1();
else if (difference<-10 && difference>10)
forward();
