Arduino linked, but upload fails
I have an Arduino UNO compatible board connected to COM10 USB port with the 1.8.8 IDE under Windows 7. The green power LED is lit, the yellow one blinks, I can Get Board Info (BN: Arduino/Genuino Uno), but when I try to upload the Fade example sketch, it fails:
Arduino: 1.8.8 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path C:\Users\Luc\AppData\Local\Temp\arduino_build_499591 -warnings=none -build-cache C:\Users\Luc\AppData\Local\Temp\arduino_cache_876583 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Fade\Fade.ino C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path C:\Users\Luc\AppData\Local\Temp\arduino_build_499591 -warnings=none -build-cache C:\Users\Luc\AppData\Local\Temp\arduino_cache_876583 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Fade\Fade.ino Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\sketch\Fade.ino.cpp" -o nul Generating function prototypes... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\sketch\Fade.ino.cpp" -o "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\preproc\ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\sketch\Fade.ino.cpp" -o "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\sketch\Fade.ino.cpp.o" Compiling libraries... Compiling core... Using precompiled core: C:\Users\Luc\AppData\Local\Temp\arduino_cache_876583\core\core_arduino_avr_pro_cpu_16MHzatmega328_0c812875ac70eb4a9b385d8fb077f54c.a Linking everything together... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.elf" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591\sketch\Fade.ino.cpp.o" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/..\arduino_cache_876583\core\core_arduino_avr_pro_cpu_16MHzatmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\Luc\AppData\Local\Temp\arduino_build_499591" -lm "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.elf" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.eep" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.elf" "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.hex" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.elf" Sketch uses 1152 bytes (3%) of program storage space. Maximum is 30720 bytes. Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes. C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM10 -b57600 -D -Uflash:w:C:\Users\Luc\AppData\Local\Temp\arduino_build_499591/Fade.ino.hex:i
avrdude: Version 6.3-20171130 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM10 Using Programmer : arduino Overriding Baud Rate : 57600 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x38 ... avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x38
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Following this link, I tried to update my driver, pointing to the Arduino driver directory, but Windows tells me the most appropriate pilot is already installed (from Arduino LLC).
Luc Le Blanc
You say you have an Uno. You’ve selected Pro Mini as the board. Since they use different bootloaders at different baud rates, it is expected to get a message like that if you have the wrong board selected.
Select Uno from tools → board and it should work.
Yes, it works. Somehow, I had assumed that getting the board info would set the board type.
Thanks!
