Arduino LM35 Temp Sensor to VB.net
Hi I am new to the programming world and i am battling to read the temp from the arduino to the vb program that i am designing for my aquarium ,the serial monitor on the arduino is displaying the readings but the vb program is not displaying it... so i found the code for it on the net and it still does not work... so need help............. i am using Microsoft Visual 2010 Express and Arduino 1.0.5 R2
Arduino Code
int tempPin = 0;
float voltage;
float degreesC;
voltage = analogRead(tempPin) * (5.0/1024.0);
degreesC = (voltage - 0.5) * 100.0;
Serial.println(degreesC);
VB Code
"Making The Visual Basic Program"
"Create a Visual Basic Windows Forms project and add a PictureBox and 2 buttons to the form."
"VB Thermometer"
" The PictureBox should be named picTherm and be 100 by 600 pixels in size."
"The buttons are called btnConnect and btnDisconnect."
"You need the following Imports at the top of the code window,"
Imports System.Drawing.Drawing2D
Imports System.IO.Ports
"You will need the following global variables,"
Dim bmp As Bitmap = New Bitmap(100, 600)
Dim temperature As Double = 10
"Now you need to click on the PictureBox, look for the events list in the Properties window and find the Paint event. Double click the space next to it. This should bring up some headers for our event handler which will be used to draw our thermometer."
Private Sub picTherm_Paint(sender As System.Object, e As System.Windows.Forms.PaintEventArgs) Handles picTherm.Paint
Dim g As Graphics = Graphics.FromImage(bmp)
g.Clear(Color.White)
' fill temperature
If temperature > 100 Then temperature = 100
If temperature < 0 Then temperature = 0
g.FillRectangle(Brushes.Red, 48, 550 - CInt(temperature * 5), 4, CInt(temperature * 5))
'draw scale
g.DrawLine(Pens.Black, 45, 550, 45, 50)
' minor ticks
For i As Integer = 50 To 550 Step 5
g.DrawLine(Pens.Black, 45, i, 48, i)
Next
'major ticks
Dim f As Font = New Font("Verdana", 8, FontStyle.Regular)
Dim scale As Integer
For i As Integer = 550 To 50 Step -25
g.DrawLine(Pens.Black, 45, i, 55, i)
scale = (550 - i) / 5
g.DrawString(Str(scale), f, Brushes.Black, 10, i - 8)
Next
picTherm.Image = bmp
End Sub
"You can test the program at this stage. It should display the value of the temperature that was hard-coded in the global variable declaration. If you change this value and run the program again, the reading on the scale should change."
Arduino Connection Code
"Add the following to the list of global variables,"
Dim WithEvents sp As New SerialPort
"Now go to the properties for the Disconnect button and set the visible property to false."
"Double click on the Connect button and write the event handler for it. You will need to change the COM port so that it matches the one your Arduino connects on."
Private Sub btnConnect_Click(sender As System.Object, e As System.EventArgs) Handles btnConnect.Click
Try
sp.BaudRate = "9600"
sp.PortName = "COM3"
sp.Open()
If sp.IsOpen Then
btnConnect.Visible = False
btnDisconnect.Visible = True
End If
Catch
sp.Close()
End Try
End Sub
"Double click on the disconnect button and write the event handler for it,"
Private Sub btnDisconnect_Click(sender As System.Object, e As System.EventArgs) Handles btnDisconnect.Click
Try
sp.Close()
btnConnect.Visible = True
btnDisconnect.Visible = False
Exit Sub
Catch
MessageBox.Show("Some kind of problem.")
End Try
End Sub
"We also need to make sure that a disconnection is made before the program is closed. Go to the properties window for the form. Click on the lightning symbol to find the list of events. Double click in the box next to Form_Closing and add the following code,"
Private Sub Form1_FormClosing(sender As System.Object, e As System.Windows.Forms.FormClosingEventArgs) Handles MyBase.FormClosing
If sp.IsOpen() Then
MessageBox.Show("Disconnect before closing")
e.Cancel = True
End If
End Sub
"Finally, we can add the code we need to read the value from the serial port and display it in our PictureBox,"
Delegate Sub myMethodDelegate(ByVal
