I have a data logging program that records data from my home heating system and logs it to ThinkSpeak. I monitor 5 zones, the boiler on/off, temperature to the system and a data point number. When any of the zones or the boiler turns on, I log the data until it turns off and then for some time after all is off. In general, the program works well, however, two times in the last 10 months, the system has locked up. Both times I powered the Arduino down and then powered it up without it having any effect - it was still locked up. Not until I connected it to a computer and opened the serial monitor would it start up again and work fine. The first time it happened, I was away for some time, so I had a neighbor cycle the power with no effect. Just now it did it again so I cycled the power two times, one for 30 seconds the other for 2 hours with no luck. Do I have a millis() rollover problem? Even if I did, wouldn't cycling the power correct it? Any suggestions on where I could start looking for the problem?
Here's my code (I'm not an experienced coder so please excuse the rough stuff! I had to remove comments to shorten it for this post):
long duration = 900;
unsigned long DELAYalloff= 120000;
unsigned long DELAYon = 60000;
#include <SparkFunESP8266WiFi.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 7
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
const char mySSID[] = "WesternDigital 2.4GHz";
const char myPSK[] = "XXXXXX";
char thingSpeakAddress[] = "api.thingspeak.com";
String APIKey = "XXXXXXXX";
long lastConnectionTime = 0;
int zone1 = 6;
int zone2 = 2;
int zone3 = 3;
int zone4 = 4;
int zone5 = 5;
int boiler = 1;
int detect = 0;
float temp = 100;
int prev1 = 1;
int prev2 = 1;
int prev3 = 1;
int prev4 = 1;
int prev5 = 1;
int prevB = 1;
int status1 = 1;
int status2 = 1;
int status3 = 1;
int status4 = 1;
int status5 = 1;
int statusB = 1;
int statussd = 1000;
int dataNo = 0;
int lastOffFlag = 0;
long lastOff = 0;
unsigned long lastDataOut = millis();
int status;
Serial.println(F("Boiler_Logger_WiFi_5.1"));
pinMode(zone1,INPUT);
pinMode(zone2,INPUT);
pinMode(zone3,INPUT);
pinMode(zone4,INPUT);
pinMode(zone5,INPUT);
digitalWrite(zone1,HIGH);
digitalWrite(zone2,HIGH);
digitalWrite(zone3,HIGH);
digitalWrite(zone4,HIGH);
digitalWrite(zone5,HIGH);
sensors.begin();
status = esp8266.begin();
if (status <= 0)
Serial.println(F("Unable to communicate with shield. Looping forever."));
while(1) ;
esp8266.setMode(ESP8266_MODE_STA); // Set WiFi mode to station
if (esp8266.status() <= 0) // If we're not already connected
if (esp8266.connect(mySSID, myPSK) < 0)
Serial.println(F("Error connecting"));
while (1) ;
Serial.print(F("My IP address is: "));
Serial.println(esp8266.localIP());
delay(3000);
Serial.println(F("Ready to record ..."));
status1 = digitalRead( zone1);
status2 = digitalRead( zone2);
status3 = digitalRead( zone3);
status4 = digitalRead( zone4);
status5 = digitalRead( zone5);
statusB = analogRead( boiler);
if (analogRead( detect) == 0)
Serial.println("Recording Stopped");
while (analogRead(detect) ==0)
delay(50);
Serial.println(F("******************Start Recording again*******************"));
if (statusB > 300)
statusB = 0; // boiler is on
statusB = 1; // boiler is off
if(statusB !=prevB || status1 !=prev1 ||
status2 !=prev2 || status3 !=prev3 || status4 !=prev4 || status5 !=prev5)
updateThingSpeak();
if (statusB != prevB)
prevB = statusB;
if (status1 != prev1)
prev1 = status1;
if (status2 != prev2)
prev2 = status2;
if (status3 != prev3)
prev3 = status3;
if (status4 != prev4)
prev4 = status4;
if (status5 != prev5)
prev5 = status5;
if(status1 ==0 || status2 == 0 || status3 == 0 || status4 == 0 || status5 == 0 || statusB == 0 )
lastOffFlag = 0;
if(millis()-lastDataOut >= DELAYon)
updateThingSpeak();
//Test to see if ALL zones are off. If yes, print for duration
if(status1 ==1 && status2 == 1 && status3 == 1 && status4 == 1 && status5 == 1 && statusB == 1 )
//Since all zones are off, look for the first time the last zone was turned off
if(lastOffFlag == 0)
if(millis()-lastDataOut >= DELAYalloff)
updateThingSpeak();
lastOff = millis()-DELAYalloff;
lastOffFlag = 1;
//Since all zones are off, test to see if the duration has not been met
if(millis() - lastOff <= duration*1000 )
updateThingSpeak();
void updateThingSpeak()
// Create a client, and initiate a connection
ESP8266Client client;
if (client.connect(thingSpeakAddress, 80) <= 0)
Serial.println(F("Failed to connect to server."));
return;
Serial.println(F("Connected."));
sensors.requestTemperatures();
temp = (sensors.getTempFByIndex(0));
if(millis()- lastConnectionTime <17000)
delay(17000-(millis()-lastConnectionTime));
dataNo +=1;
//read boiler again in case it has changed during the delay
if (analogRead( boiler) > 300)
// Set up our post parameters:
String params;
params += "field1=" + String(statusB)+ "&";
params += "field2=" + String(digitalRead( zone1))+ "&";
params += "field3=" + String(digitalRead( zone2))+ "&";
params += "field4=" + String(digitalRead( zone3))+ "&";
params += "field5=" + String(digitalRead( zone4))+ "&";
params += "field6=" + String(digitalRead( zone5))+ "&";
params += "field7=" + String(temp)+ "&";
params += "field8=" + String(dataNo);
Serial.println(F("Posting to thingspeak!"));
Serial.println(params);
Serial.print("Data Points: ");
Serial.println(dataNo);
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(params.length());
client.print("\n\n");
client.print(params);
lastConnectionTime = millis();
// available() will return the number of characters
// currently in the receive buffer.
while (client.available())
Serial.write(client.read()); // read() gets the FIFO char
// connected() is a boolean return value - 1 if the
// connection is active, 0 if it's closed.
if (client.connected())
client.stop(); // stop() closes a TCP connection.
lastDataOut=millis(); //last time data printed
Here is the last bit of data before it crashed:
created_at entry_id ID field1 field2 field3 field4 field5 field6 field7 field8
2017-10-20 23:41:17 UTC 8920 0 1 1 1 1 1 71.71 12941
2017-10-20 23:42:21 UTC 8921 0 1 1 1 1 1 71.6 12942
2017-10-20 23:44:25 UTC 8922 0 1 1 1 1 1 71.71 12944
