ARDUINO logo on a 16x2 LCD
made the arduino logo in little bits, but then it struck me, you can only have 8 character sets at 1 time. So for now i’m shifting upperpart en lowerpart.
Is there a way around this, because for now you’ll get a flickering logo.
the code:
Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
library works with all LCD displays that are compatible with the Hitachi HD44780 driver.
This sketch is used for testing the lcd.createChar function.
Demo by JO3RI
// include the library code:
#include  <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set speed for shift upper - lower part:
int x=25;
	// set up the LCD's number of columns and rows:
	lcd.begin(16,2);
	// clear the LCD screen:
	lcd.clear();
	// start the arduinologo part:
	arduinologo();
//the arduinologo logo itself
void arduinologo(){
	upperpart();
        lcd.setCursor(4,0);
	lcd.write(0);
	lcd.setCursor(5,0);
	lcd.write(1);
	lcd.setCursor(6,0);
	lcd.write(2);
	lcd.setCursor(7,0);
	lcd.write(3);
	lcd.setCursor(8,0);
	lcd.write(4);
	lcd.setCursor(9,0);
	lcd.write(5);
	lcd.setCursor(10,0);
	lcd.write(6);
	lcd.setCursor(11,0);
	lcd.write(7);
        delay(x);
        lcd.clear();
        lowerpart();
        lcd.setCursor(4,1);
	lcd.write(0);
	lcd.setCursor(5,1);
	lcd.write(1);
	lcd.setCursor(6,1);
	lcd.write(2);
	lcd.setCursor(7,1);
	lcd.write(3);
	lcd.setCursor(8,1);
	lcd.write(4);
	lcd.setCursor(9,1);
	lcd.write(5);
	lcd.setCursor(10,1);
	lcd.write(6);
	lcd.setCursor(11,1);
	lcd.write(7);
        delay(x);
        lcd.clear();
void upperpart(){
        byte logoARD1a[8] = {B00000,B00000,B00001,B00011,B00111,B00111,B01110,B01110};
        byte logoARD2a[8] = {B00111,B11111,B11111,B11000,B10000,B00000,B00000,B00111};
        byte logoARD3a[8] = {B11100,B11111,B11111,B00011,B00000,B00000,B00000,B11100};
        byte logoARD4a[8] = {B00000,B00000,B11000,B11100,B11110,B01111,B01111,B00111};
        byte logoARD5a[8] = {B00000,B00000,B00011,B00111,B01111,B11110,B11110,B11100};
        byte logoARD6a[8] = {B00111,B11111,B11111,B11000,B00000,B00001,B00001,B00111};
        byte logoARD7a[8] = {B11100,B11111,B11111,B00011,B00001,B10000,B10000,B11100};
        byte logoARD8a[8] = {B00000,B00000,B10000,B11000,B11100,B11100,B01110,B01110};
	lcd.createChar(0, logoARD1a);
	lcd.createChar(1, logoARD2a);
	lcd.createChar(2, logoARD3a);
	lcd.createChar(3, logoARD4a);
	lcd.createChar(4, logoARD5a);
	lcd.createChar(5, logoARD6a);
	lcd.createChar(6, logoARD7a);
	lcd.createChar(7, logoARD8a);
void lowerpart(){
        byte logoARD9a[8] = {B01110,B01110,B00111,B00111,B00011,B00001,B00000,B00000};
        byte logoARD10a[8] = {B00111,B00000,B00000,B10000,B11000,B11111,B11111,B00111};
        byte logoARD11a[8] = {B11100,B00000,B00000,B00000,B00011,B11111,B11111,B11100};
        byte logoARD12a[8] = {B00111,B01111,B01111,B11110,B11100,B11000,B00000,B00000};
        byte logoARD13a[8] = {B11100,B11110,B11110,B01111,B00111,B00011,B00000,B00000};
        byte logoARD14a[8] = {B00111,B00001,B00001,B00000,B11000,B11111,B11111,B00111};
        byte logoARD15a[8] = {B11100,B10000,B10000,B00000,B00011,B11111,B11111,B11100};
        byte logoARD16a[8] = {B01110,B01110,B11100,B11100,B11000,B10000,B00000,B00000};
	lcd.createChar(0, logoARD9a);
	lcd.createChar(1, logoARD10a);
	lcd.createChar(2, logoARD11a);
	lcd.createChar(3, logoARD12a);
	lcd.createChar(4, logoARD13a);
	lcd.createChar(5, logoARD14a);
	lcd.createChar(6, logoARD15a);
	lcd.createChar(7, logoARD16a);
Cool! I wish I had an answer. 8)
JO3RI: Is there a way around this, because for now you'll get a flickering logo.
Not on a 16x2 there isn't.
You can either make in 8 character spaces or you could use a display with more than one HD44780 controller. This was briefly discussed in another thread. For example, on a 40x4, you can have 8 custom characters on the top two lines and 8 on the bottom two lines as it has two chips, one controlling the top two and one controlling the bottom two. Then you could do the logo across the middle two lines (or all four if you were clever with the design)
Ok, so we have an answer. I'll lock this topic, Thanks
Unlocked it just to put an image for reference, and I’ll leave it open for a bit longer :slight_smile:
Ok, and because someone probably would ask, here is a video
http://www.youtube.com/watch?v=5wX_HwBAgvc
Where? :D
Ahh, that'll be just on my side - lemme try a different browser...
Yep, there it is.
