I hadn't thought about this, mainly because I believe it requires multiple cameras to do this and the cost is very high. I wanted something that I could make relatively cheap (£30-40 each) to save money and learn more about Arduino and electronics in the process.
I didn't realise that. This seems to be the problem I keep running into. Is there any method that can receive transmissions from multiple devices?
I'm not attached to the idea of using NRF24s, it was just something I came across while researching.
It seems like the only option (apart from video and image processing) is to have multiple receivers for NRF24s or HC-12s at a base station with an antenna. However, would it be possible to have 11+ receivers all talking to one PC?
EDIT
Another thought, if transmission of data is quick then it could be an option to pass information along a single line path. So one player 1 sends their data to player 2. Player 2 then adds their data to player 1's data to send to player 3. Player 3 then adds their data to what they receive (player 1 & player 2 data) then passes it on. As the position is updated every second, I guess this would mean the data would have to pass onto the next unit within ~80ms. Even at speeds of 250 kbps, this should be achievable. Would this realistically work?
So if one of the radios fails you get no data at all, good plan.
You seem to be wanting (or rather asking the forum to) design this system before you know the basics of what will work for you, given the distances and the data rates you can utilise.
Once you know how fast a particular radio can send the data required, over the range and circumstances required, you will know the air time of the data. Once you know this you can estimate the chances of data collisions if all transmitters are just sending at random.
Or, once you know the data rate, you can test how long it would take to poll each of the transmitters for the data required. It might be fast enough.
But unless you test to see what data rate a particular module can achieve, it seems pointless to conjecture what would be a practical system.
You need audio transmitter/receiver +stm32f103 which can handle fft up to 20 kHz, fft = multi channel receiver, audio generator with different frequency for each player, 1kHz,2kHz ..........11kHz and 11 GPS.
GPS data is used to modulate audio generator , so you have 11 Tx transmitting data on different audio frequencies and fft with 11 bins …
