Arduino Looping states in Void Loop help needed for a novice.
See reply #18
more or less this is in a doubled sense (almost) fully functional description.
still missing some parts. What would be so hard to follow the instructions in post #18??
As a consequence of not following the instructions I will bomb you with a lot of new information. Let's see if you can cope with that:
As you have only two states it is still doable with if-conditions.
and it can be done like Bob suggested with writing it as pseudo code.
For functionalities that have more than two "states" a switch-case statement is more suitable.
Depending on the value of your variable "count" the next button-press switches from state 1 (= blinking LED on IO-pin 2 to state 2 (blinking LED on io-Pin 7)
or vice versa.
You should divide programs into small functions where each function does one thing.
there is a function "blink LED 1"
and
a function "blink LED 2"
blinking can be done by inverting the current state of the IO-pin
There is another command similar to digitalWrite.
digitalRead.
Even if an IO-pin is configured as output you still can read the state of the IO-pin.
some example-codes that show how digitalRead can be used for blinking
simply blinking LED 2:
  digitalWrite(Pin2,HIGH);
  delay(400);
  digitalWrite(Pin2,LOW);
  delay(400);
making the actual state of the IO-pin visible in the serial monitor
  if (digitalRead(Pin2) == HIGH) {
    Serial.println("Pin2 is HIGH");
  delay(400);
  if (digitalRead(Pin2) == LOW) {
  delay(400);
using digitalRead to get the actual state of the IO-pin
  byte IO_PinState = digitalRead(Pin2);
  if (IO_PinState == LOW) {
    digitalWrite(Pin2,HIGH); // set to opposite state
  if (IO_PinState == HIGH) {
    digitalWrite(Pin2,LOW); // set to opposite state
  delay(400);
This can be done even shorter with the not-operator "!"
! HIGH results in LOW
! LOW results in HIGH
Do you see the not-operator ?! The attention-mark "!"
which combines the digitalRead with the digitalWrite
    digitalWrite(Pin2, !digitalRead(Pin2) ); // set to opposite state by using the not-operator
    delay(400);
digitalWrite (first parameter , second parameter )
first parameter like always "Pin2"
second parameter result of !digitalRead(Pin2)
digitalRead(Pin2) // if the IO-pin is set to state HIGH the result of "digitalRead is HIGH
digitalRead(Pin2) // if the IO-pin is set to state LOW the result of "digitalRead is LOW
The not-operator inverts this result
!HIGH results in LOW
!LOW results in HIGH
so the IO-pin gets switched always to the opposite state LOW-HIGH-LOW-HIGH-LOW-HIGH = blinking
This could be packed into a function
for LED on IO-pin 2
void Blink_LED_A() {
  delay(400);
for LED on IO-pin 7
void Blink_LED_B() {
  digitalWrite(Pin7, !digitalRead(Pin7) ); // set to opposite state by using the not-operator
  delay(400);
and then the functions were called inside loop
  Blink_LED_A()
  Blink_LED_B()
This is already pretty much new stuff.
So try it and report results whatever the results will be.
always post your whole code as a code-section to make everything clear
best regards Stefan
I am still very new. Sorry but I don't understand the example?
unsufficient answer: there are about 10 examples in this thread
quote the example you don't understand and post the code of the example you don't understand as a code-section
Do you know how to increment a count every time a button becomes pressed ?
Do you know how to test the value of a variable and run different code based on its value ?
why does changing the LEDs, not which pattern, depend on the button state?
