Hello! I am new to Arduino and LoRa and need some help.
I managed to transmit data from an Arduino to a Raspberry Pi and back, so communication works.
I want to transmit 1 byte ID, 2 bytes sensor data and 2 bytes counter variable (int) in hex format.
My problem is that the first 3 bytes are transmitted and received correctly, but the counter variable is ignored. If I set any byte to 0x00 the data after is ignored and not sent.
What am I doing wrong here or is it not allowed to transmit 0x00?
Thanks for your help!
That depends a lot on how the content is sent and received. Post complete code (and use code tags)!
#include <SPI.h>
#include <LoRa.h>
while (!Serial);
Serial.println("LoRa Receiver");
if (!LoRa.begin(434E6)) {
Serial.println("Starting LoRa failed!");
while (1);
LoRa.setSpreadingFactor(12);
LoRa.setSignalBandwidth(250000);
LoRa.setCodingRate4(8);
LoRa.enableCrc();
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
uint8_t input = (uint8_t)LoRa.read();
Serial.print(input);
Serial.print("(0x");
Serial.print(input, HEX);
Serial.print(")");
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
The output in putty from the receiver is:
Received packet ‘30(0x1E)65(0x41)66(0x42)67(0x43)68(0x44)69(0x45)70(0x46)71(0x47)72(0x48)’ with RSSI -39
Received packet ‘30(0x1E)65(0x41)66(0x42)67(0x43)68(0x44)69(0x45)70(0x46)71(0x47)72(0x48)1(0x1)’ with RSSI -39
Received packet ‘30(0x1E)65(0x41)66(0x42)67(0x43)68(0x44)69(0x45)70(0x46)71(0x47)72(0x48)2(0x2)’ with RSSI -38
Received packet ‘30(0x1E)65(0x41)66(0x42)67(0x43)68(0x44)69(0x45)70(0x46)71(0x47)72(0x48)3(0x3)’ with RSSI -38
If I write data[5] = 0x00 the receiver output is:
Received packet ‘30(0x1E)65(0x41)66(0x42)67(0x43)68(0x44)’ with RSSI -29
Received packet ‘30(0x1E)65(0x41)66(0x42)67(0x43)68(0x44)’ with RSSI -28
The print method expects a null byte terminated string (character array). Your data hasn't that format so it will send more data until it finds a null byte in memory.
As you found out yourself, the write method allows you to specify the length of the provided data and that way you can transmit any data you like.
