Hello,
Couple of weeks back I did a room temperature logger on a breadboard, using a DHT21 sensor, an SD module, and an RTC module. So far, so good working off of mains. I've got tens of thousands of data points for processing, did some cross checks with a room thermometer, all good.
Now the next thing I want to do is take this thing off mains, so I can run it off batteries. I'm planning on the usual setup: the ATMEGA328 chip by itself + switching regulator + modules mounted on a custom made PCB. I've been looking into the arduino low power libraries, which seems to be the way to go.
The idea I have is to keep the CPU running on low power standby, when it wakes up every so often, it takes a reading. And I figure I can improve the power consumption a whole bunch if the CPU cuts power to the sensors and modules, goes to sleep, and then powers each module back on only when it's needed. In fact that would probably allow me to add an RF transmitting module and make it play nice with the SD module, but that's another story.
I was thinking of simply putting 4 or 5 transistors on the VCC line and using them to switch power off and on. But that might take up a bit of space and a small mess of traces on the PCB. So I got to thinking ICs: a shift register, sourcing power from it is my current idea.
Or a LED display driver, but I'm thinking a LED display driver is probably overkill and more complicated than it's worth.
I also found chips like the ULN2803 which are darlington arrays, but I don't see the need for darlington pairs for simply switching things off and on.
Anybody have a better idea for this switching setup? Is there any IC I can look into that's just a bunch of transistors in parallel, for this kind of application?
