Hello all
I am trying to write code on the Romi bot Pololu - Romi Chassis Kit - Red which uses the Arduino*-compatible ATmega32U4 MCU board. This also has a IMU LSM6DS33 installed.
All i want is to write a function say void turn(90) and the romi bot should turn 90 degrees.
I have tried the following sketch from examples to read the Z value where Romi is pointing. If romi is not moving ( which it is not) i expect the Z value to be same... but its not so.. the Z value keeps changing as if the romi is moving
what am i doing wrong or what do i need to do more...
// ****** START CODE********//
#include <Wire.h>
#include <LSM6.h>
LSM6 imu;
char report[80];
Wire.begin();
if (!imu.init())
Serial.println("Failed to detect and initialize IMU!");
while (1);
imu.enableDefault();
imu.read();
snprintf(report, sizeof(report), "A: %6d %6d %6d G: %6d %6d %6d",
imu.a.x, imu.a.y, imu.a.z,
imu.g.x, imu.g.y, imu.g.z);
Serial.println(report);
delay(100);
//******* END CODE*********//```
The code compiles and runs but even if romi is not moving i keep getting values of Z that are not the same. My expectation is that if the Romi is not moving then Z value should not change..
sample out put The last col is the gyroscope Z value and it keeps changing
A: 367 -8 16750 G: 285 -263 -748
A: 435 37 16612 G: 206 -189 -616
A: 316 -12 16641 G: 261 -489 -602
A: 321 -2 17027 G: 230 -147 -628
A: 583 -13 16615 G: 204 9 -558
A: 298 -12 16711 G: 223 -44 -733
