Arduino M0 Pro MIDI Device with Ableton help!
Hi!
I've been trying to turn my Arduino M0 Pro into a Midi Device that's linked to Ableton. Essentially, all I want is to have the buttons on my breadboard mute and unmute a track on Ableton.
I've managed to map the unmute button on Ableton through their MIDI mapping function, but when it press the button on my circuit, it only unmutes it for ONE second. How would I edit the code in order to make it a permanent change of state from mute to unmute?
My understanding of the programming language is not strong, so I've essentially copied the code from the Arduino guide: https://www.arduino.cc/en/Tutorial/MidiDevice.
#include "MIDIUSB.h"
#include "PitchToNote.h"
#define NUM_BUTTONS 7
#define C8 108
#define B7 107
#define B7b 106
#define A7 105
#define A7b 104
#define G7 103
#define G7b 102
#define F7 101
#define E7 100
#define E7b 99
#define D7 98
#define D7b 97
#define C7 96
#define B6 95
#define B6b 94
#define A6 93
#define A6b 92
#define G6 91
#define G6b 90
#define F6 89
#define E6 88
#define E6b 87
#define D6 86
#define D6b 85
#define C6 84
#define B5 83
#define B5b 82
#define A5 81
#define A5b 80
#define G5 79
#define G5b 78
#define F5 77
#define E5 76
#define E5b 75
#define D5 74
#define D5b 73
#define C5 72
#define B4 71
#define B4b 70
#define A4 69
#define A4b 68
#define G4 67
#define G4b 66
#define F4 65
#define E4 64
#define E4b 63
#define D4 62
#define D4b 61
#define C4 60
#define B3 59
#define B3b 58
#define A3 57
#define A3b 56
#define G3 55
#define G3b 54
#define F3 53
#define E3 52
#define E3b 51
#define D3 50
#define D3b 49
#define C3 48
#define B2 47
#define B2b 46
#define A2 45
#define A2b 44
#define G2 43
#define G2b 42
#define F2 41
#define E2 40
#define E2b 39
#define D2 38
#define D2b 37
#define C2 36
#define B1 35
#define B1b 34
#define A1 33
#define A1b 32
#define G1 31
#define G1b 30
#define F1 29
#define E1 28
#define E1b 27
#define D1 26
#define D1b 25
#define C1 24
#define B0 23
#define B0b 22
#define A0 21
const uint8_t button1 = 2;
const uint8_t button2 = 3;
const uint8_t button3 = 4;
const uint8_t button4 = 5;
const uint8_t button5 = 6;
const uint8_t button6 = 7;
const uint8_t button7 = 8;
const int intensityPot = 0; //A0 input
const uint8_t buttons[NUM_BUTTONS] = {button1, button2, button3, button4, button5, button6, button7};
const byte notePitches[NUM_BUTTONS] = {C3, D3, E3, F3, G3, A3, B3};
uint8_t notesTime[NUM_BUTTONS];
uint8_t pressedButtons = 0x00;
uint8_t previousButtons = 0x00;
uint8_t intensity;
for (int i = 0; i < NUM_BUTTONS; i++)
pinMode(buttons*, INPUT_PULLUP);*
  • readButtons();*
  • readIntensity();*
  • playNotes();*
    // First parameter is the event type (0x0B = control change).
    // Second parameter is the event type, combined with the channel.
    // Third parameter is the control number number (0-119).
    // Fourth parameter is the control value (0-127).
    void controlChange(byte channel, byte control, byte value) {
  • midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};*
  • MidiUSB.sendMIDI(event);*
    void readButtons()
  • for (int i = 0; i < NUM_BUTTONS; i++)*
    _ if (digitalRead(buttons*) == LOW)_
    _
    {_
    _
    bitWrite(pressedButtons, i, 1);_
    _
    delay(50);_
    _
    }_
    _
    else*_
    * bitWrite(pressedButtons, i, 0);*
    void readIntensity()
    * int val = analogRead(intensityPot);*
    * intensity = (uint8_t) (map(val, 0, 1023, 0, 127));
    _
    }_
    void playNotes()
    _
    {_
    _
    {_
    _
    if (bitRead(pressedButtons, i) != bitRead(previousButtons, i))_
    _
    {_
    _
    if (bitRead(pressedButtons, i))_
    _
    {_
    _
    bitWrite(previousButtons, i , 1);_
    _ noteOn(0, notePitches, intensity);
    MidiUSB.flush();
    else*
    bitWrite(previousButtons, i , 0);
    noteOff(0, notePitches, 0);
    MidiUSB.flush();
    // First parameter is the event type (0x09 = note on, 0x08 = note off).
    // Second parameter is note-on/note-off, combined with the channel.
    // Channel can be anything between 0-15. Typically reported to the user as 1-16.
    // Third parameter is the note number (48 = middle C).
    // Fourth parameter is the velocity (64 = normal, 127 = fastest).
    void noteOn(byte channel, byte pitch, byte velocity) {_
    midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
    _ MidiUSB.sendMIDI(noteOn);
    void noteOff(byte channel, byte pitch, byte velocity) {_
    midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
    _ MidiUSB.sendMIDI(noteOff);
    [/quote]
    I know that this code is very extra and likely to be incorrect for what I need, but I'm not sure how to continue.
    I've attached an image of what my circuit with the button looks like here: https://ibb.co/nE6iVn*_
    As well as a screenshot on hairless, as my button works.
    Any advice on how I should change the code to do this?
    Thanks!!!!!
    __
