Hello everyone, I won an Arduino M0 but I didn't find its usb cable in it. Unfortunately, I don't have it, can anyone tell me an url of a M0 cable in Ebay? Or, is there a way to pass the code from an arduino board (UNO in my case) to another board (M0 in my case)? Thanks you for your help!
Hi. I hope these links will able to help you out on how to program M0..
and
http://tronixstuff.com/2015/10/28/review-arduino-m0-pro-with-32-bit-arm-cortex-m0/
To connect the Arduino M0 to your computer, you'll need a Micro-B USB cable which can easily be located online or your nearest electronics store.
Thanks a lot for your answer, this helped me a lot.
Just one question more, how many servos do you think can a M0 supply? Thanks you again
You can use as many as there are pins, I think.
All you need is an external power source, the arduino cannot give enough current to drive servos.
Connect the positive side of the power source to the 5v wire of the servo, connect both grounds (arduino and power) to the grounds of the servo, then connect the arduino's digital pins to the signal wires of the servo.
Arduino might be able to power a small servo though but if you need more servos like for a hexapod etc. you need an external power source...
