Hi! I've few questions about Arduino Manager with Arduino yun. I can't make it work.
Sorry for this noob questions, I already emailed fab, hes not answering.
Do I still need any Shields or Ethernet shield If I'm already using Arduino yun? In the documentation it says it's required but yun has ethernet port.
Since im using YUN, the software that I need to upload to Arduino is TestArduinoManagerForYun Right?
3.Can I use Arduino Manager without using the Ethernet Cable? I already can upload sketch thru Wifi.
In the "TestArduinoManagerForYun" sketch, there's no part of the sketch that I need to put my IP Address or MAC, does it mean I don't need to?
5.Aside from the port number, Do I need to edit TestArduinoManagerForYun to make it work?
I can see the WAN led blinks when Im clicking Buttons on Arduino manager but nothings happening on arduino pins, it stays LOW. I tried with multimeter and leds.
Thanks for the reply! I can't make it work:( When i use port 80 the wan led blinks when i push button on my arduino manager, using other port numbers doesnt do that. Using port 80 it seems working cause the yun led blinks but its all it can do.
