just started using Arduino manager and the code generator.The code is directly from the code generator I am trying to read a input value from pin a4 its been a long time since I played with Arduino so I am a bit lost can anyone help me please
thanks
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_aug10a:28: error: conflicting declaration 'float A4'
float A4;
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:249:0,
from sketch\sketch_aug10a.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega/pins_arduino.h:72:22: note: previous declaration as 'const uint8_t A4'
static const uint8_t A4 = PIN_A4;
C:\Users\barrd\Documents\Arduino\bluetooth\sketch_aug10a\sketch_aug10a.ino: In function 'void processOutgoingMessages()':
C:\Users\barrd\Documents\Arduino\bluetooth\sketch_aug10a\sketch_aug10a.ino:118:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
iosController.writeMessage("A4",A4);
C:\Users\barrd\Documents\Arduino\bluetooth\sketch_aug10a\sketch_aug10a.ino: In function 'void switchPin2SyncCallback()':
C:\Users\barrd\Documents\Arduino\bluetooth\sketch_aug10a\sketch_aug10a.ino:136:58: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
iosController.writeMessage("Pin2",digitalRead(Pin2_PIN));
exit status 1
option enabled in File -> Preferences.
* This file has been generated with Arduino Manager for iPhone/iPad version: 10.1
* https://itunes.apple.com/it/app/arduino-manager/id497240094?l=en&mt=8
* For more information write to fabboco@gmail.com
#include <RBL_nRF8001.h>
#include <SPI.h>
#include <boards.h>
#include <IOSControllerBLE.h>
#define Pin2_PIN 2
/* Start your code (defines) */
/* End your code */
* IOSController Library initialization
IOSControllerBLE iosController(&doWork,&doSync,&processIncomingMessages,&processOutgoingMessages,NULL,NULL);
/******* Start Global Variable for Widgets *******/
float A4;
/******* End Global Variable for Widgets *******/
ble_begin();
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
pinMode(10,OUTPUT);
digitalWrite(10,LOW);
pinMode(Pin2_PIN,OUTPUT);
digitalWrite(Pin2_PIN,LOW);
/* Start your code (setup) */
/* End your code */
iosController.loop();
* This function is called periodically and it is equivalent to the standard loop() function
void doWork() {
/* Start your code (doWork) */
/* End your code */
* This function is called when the ios device connects and needs to initialize the position of switches and knobs
void doSync (char *variable) {
if(strcmp(variable,"Pin2")==0) {
switchPin2SyncCallback();
/* Start your code (doSync) */
/* End your code */
* This function is called when a new message is received from the iOS device
void processIncomingMessages(char *variable, char *value) {
switchPin2Callback(atoi(value));
/* Start your code (processIncomingMessages) */
/* End your code */
* This function is called periodically and messages can be sent to the iOS device
void processOutgoingMessages() {
/* Start your code (processOutgoingMessages) */
/* End your code */
/* Widgets synchronization callbacks */
void switchPin2SyncCallback() {
/* Start your code (switchPin2SyncCallback) */
//iosController.writeMessage("Pin2",Insert value here);
/* End your code */
/* Widgets operations callbacks */
void switchPin2Callback(boolean on) {
/* Start your code (switchPin2Callback) */
/* End your code */
digitalWrite(Pin2_PIN,on);
/* Analog input preprocess functions */
/**** User Functions *****/
/* Start your code (User Functions) */
/* End your code */
