arduino manager
having problems with analogy read I have a potentiometer wired to a0 on mega and led on pin
on the ipad Arduino manager I have a switch widget named led d2 this switches the led on and of and works perfect .
and I have a gauge called pot0 widget to read the input from a0 but this will not work
can anyone help ? thankyou for taking the time to look
 * This file has been generated with Arduino Manager for iPhone/iPad version: 10.1
 * https://itunes.apple.com/it/app/arduino-manager/id497240094?l=en&mt=8
 * For more information write to fabboco@gmail.com
#include <RBL_nRF8001.h>
#include <SPI.h>
#include <boards.h>
#include <IOSControllerBLE.h>
#define Led_2_PIN			2
/* Start your code (defines) */
/* End your code */
 * IOSController Library initialization
IOSControllerBLE iosController(&doWork,&doSync,&processIncomingMessages,&processOutgoingMessages,&deviceConnected,&deviceDisconnected);
/******* Start Global Variable for Widgets *******/
float Pot0;
/******* End Global Variable for Widgets *******/
  ble_begin();
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  pinMode(53,OUTPUT);
  digitalWrite(53,LOW);
  pinMode(Led_2_PIN,OUTPUT);
  digitalWrite(Led_2_PIN,HIGH);
  /* Start your code (setup) */
  /* End your code */
  iosController.loop();
* This function is called periodically and it is equivalent to the standard loop() function
void doWork() {
  /* Start your code (doWork) */
  /* End your code */
* This function is called when the ios device connects and needs to initialize the position of switches and knobs
void doSync (char *variable) {
  if(strcmp(variable,"Led 2")==0) {
    switchLed_2SyncCallback();
  /* Start your code (doSync) */
  /* End your code */
* This function is called when a new message is received from the iOS device
void processIncomingMessages(char *variable, char *value) {
    switchLed_2Callback(atoi(value));
  /* Start your code (processIncomingMessages) */
  /* End your code */
* This function is called periodically and messages can be sent to the iOS device
void processOutgoingMessages() {
  iosController.writeMessage("Pot0",Pot0);
  /* Start your code (processOutgoingMessages) */
  /* End your code */
void deviceConnected () {
  /* Start your code (deviceConnected) */
  /* End your code */
void deviceDisconnected () {
  /* Start your code (deviceDisconnected) */
  /* End your code */
/* Widgets synchronization callbacks */
void switchLed_2SyncCallback() {
  /* Start your code (switchLed_2SyncCallback) */
  //iosController.writeMessage("Led 2",Insert value here);
  /* End your code */
  iosController.writeMessage("Led_2",digitalRead(Led_2_PIN));
/* Widgets operations callbacks */
void switchLed_2Callback(boolean on) {
  /* Start your code (switchLed_2Callback) */
  /* End your code */
  digitalWrite(Led_2_PIN,on);
/* Analog input preprocess functions */
/**** User Functions *****/
/* Start your code (User Functions) */
/* End your code */
maddave wrote (in part):
but a potentiometer has three terminals, so this does not really describe the wiring. Please provide a sketch or diagram or schematic or something of the real wiring.
led on pin
I do not know what this even means, but the code suggests that the LED is on pin 2.
I do not know "the ipad Arduino manager" so I cannot really help, but I suspect the wiring if the "pot0 widget to read the input from a0 but this will not work ".
sorry should say led on d2 pin
I missed the mention of the A0 pin in the code, where is it?
