I'm interfacing an Arduino Uno with matlab, using the arduino as a real time DAQ and PWM generator.
Arduino receives a duty cycle value to generate the right PWM wave and sends back a couple of analog inputs, all real-time, all through the usb communication interface.
The time it takes for the arduino to send back a value via USB and for matlab to receive it is mostly around 1-0.7 ms, but every few fractions of second the delay jumps up to 20-25x higher at 20-25ms.
I'm using the arduino as a real time daq: Simulink uses the real time data to compute a quite complex control scheme (model predictive control). The system is very slow (useful modes between 0.1Hz and 2Hz) so i don't need extreme sampling speeds, but 25ms leaves me a too tight margin to compute the control action, which must run at a fixed frequency.
I tried to use the Matlab-Arduino package (provided on the Mathworks website) and the results were similar but with even more peak latency.
I'm using just a Serial.println(sensor_value) on the arduino side and an fscanf(serialPort,'%s') on the matlab side, with the right tricks to acknowledge the data in the right format.
Anyone can help? Is this an interface limit?
Thank you
Arduino's code:
int ledPin = 13;
int sensorPin = A0;
int num;
int matlab=0;
int start=0;
short sensor;
pinMode(ledPin,INPUT);
pinMode(A0,INPUT);
while(Serial.available()>0) {
start = Serial.read();
delay(1);
while(start==1){
sensor = analogRead(A0);
Serial.println(sensor);
delay(10);
-Matlab's code:
%receive and convert an int from
% 0 to 1023
clc
clear all
serialPort=serial('COM4','BaudRate',115200); %port initialization
set(serialPort,'InputBufferSize',5)
set(serialPort,'Timeout',2)
fopen(serialPort); % port opening
i=1;
tic
disp('start')
while(serialPort.BytesAvailable == 0)
fprintf(serialPort,'%s',char(start)); % send answer variable content to arduino
disp('connecting')
end
disp('connected')
while(i < 1000)
if(serialPort.BytesAvailable > 0)
tic
data_received = fscanf(serialPort,'%s',4);
data_received = [data_received fscanf(serialPort,'%s')];
duration(i) = toc;
data(i) = str2num(data_received);
i = i+1;
end
i
end
fclose(serialPort);
