Arduino MAX 2560 and pulseoxometer MAX30102 not initialising
So I'm trying to connect a MAX30102 pulseoxometer to an arduino MEGA2560 using the code below:
#include <Wire.h>
#include "MAX30105.h"
MAX30105 particleSensor; // initialize MAX30102 with I2C
  while(!Serial); //We must wait for Teensy to come online
  delay(100);
  Serial.println("");
  Serial.println("MAX30102");
  Serial.println("");
  delay(100);
  // Initialize sensor
  if (particleSensor.begin(Wire, I2C_SPEED_FAST) == false) //Use default I2C port, 400kHz speed
    Serial.println("MAX30105 was not found. Please check wiring/power. ");
    while (1);
  byte ledBrightness = 70; //Options: 0=Off to 255=50mA
  byte sampleAverage = 1; //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  int sampleRate = 400; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 69; //Options: 69, 118, 215, 411
  int adcRange = 16384; //Options: 2048, 4096, 8192, 16384
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
  particleSensor.check(); //Check the sensor
  while (particleSensor.available()) {
      // read stored IR
      Serial.print(particleSensor.getFIFOIR());
      Serial.print(",");
      // read stored red
      Serial.println(particleSensor.getFIFORed());
      // read next set of samples
      particleSensor.nextSample();
but when running it and looking at my COM monitor I only see this
or other random characters.
The connections are as such (with no additional components in-between):
  • VIN - 3,3V
  • SDA - A0
  • SCL - A1
  • GND - GND
I tried the same on an Arduino UNO with the same program and schematic but to no avail.
The boards themselves seem to be fine as they run all my other programs for different projects.
Your serial monitor needs to be set to 115200 baud.
I set it to 9600 and it works
EDIT: I'm an idiot and only now did I realise how to change the monitor rate...
Great!
