Hi I hope that you are fine.
I got an issue that seems to be very common on the net, is that the screen of the 2.8 TFT display stays white no matter what libraries are installed. I followed all instructions and did everything, yet my problem isn't solved. Only one code that I found on internet seemed to do something considerable.
I am using an ARDUINO MEGA 2560
The ID that I get is : 0x6051 and it seems to be not supported by any library. The issue is that I'm working on a project with that and submission is after 3 days…
The output using adafruit library is :
TFT LCD test
Using Adafruit 2.8" TFT Breakout Board Pinout
TFT size is 240x320
Unknown LCD driver chip: 0
If using the Adafruit 2.8" TFT Arduino shield, the line:
#define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
Also if using the breakout, double-check that all wiring matches the tutorial.
with mcufriend library : graphictest example :
Serial took 0ms to start
ID = 0x6051
code that worked : /*********************************************************************
* LCD_ID_Reader
* This sketch is meant only to attempt to read the driver ID code
* from inexpensive touchscreen LCDs found on eBay without needing to
* load any additional libraries. The hope is to identify the most
* common varieties and choose the best library for the screen you have.
* This has been successfully tested so far on 992X and 778X variety
* screens.
* Usage:
* Compile the sketch and run it on your board with the screen
* attached. In the serial monitor, you should see a message containing
* the driver code. The tricky thing is that if it does not work, the
* results may be undetermined. However, if we can compile a list,
* the difference between working and not may become more evident.
* Please visit http://misc.ws/lcd_information for more information.
* Version 1.2 - January 29th, 2015
* PIN ASSIGNMENTS
* You can alter the pin assignments to reflect any configuration you
* wish. I've provided the default shield configuration, which works
* on both the Arduino UNO and Mega 2560.
//-- Arduino UNO or Mega 2560 Plugged as shield
#define LCD_RST A4
#define LCD_CS A3
#define LCD_RS A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_D0 8
#define LCD_D1 9
#define LCD_D2 2
#define LCD_D3 3
#define LCD_D4 4
#define LCD_D5 5
#define LCD_D6 6
#define LCD_D7 7
* Attempt to initialize and reset LCD, then read its Driver Code
* at register index 0.
char hexString[7];
uint16_t id;
Serial.println("Initializing LCD...");
lcdInit();
lcdReset();
Serial.print("Reading ID...");
id = lcdReadID();
sprintf(hexString, "0x%0.4X", id);
Serial.println( hexString );
if( id == 0x7783 ) {
lcdRegister7783();
lcdFillScreen(0xF800);
Serial.println("If your screen filled red, then you may be able to use the library at https://github.com/Smoke-And-Wires/TFT-Shield-Example-Code");
} else if( id == 0x0154 ) {
lcdRegister0154();
Serial.println("If your screen filled red, please report it at http://misc.ws/lcd_information");
Serial.println("There is currently no known working library.");
lcdRegisterOther();
Serial.println("If your screen filled red, you may be able to use the library at http://misc.ws");
//print_all_regs();
void print_all_regs() {
char str[60];
uint16_t i, val;
for(i=0; i < 256; i++ )
delay(40);
val = lcdReadRegister(i);
sprintf(str, "Register 0x%0.2X : 0x%0.4X", i, val);
Serial.println( str );
* LCD Functions - Inefficient but should be good enough
* to read the ID.
void lcdRegister0154() {
lcdWriteRegister(0x000C, 0x130);
lcdWriteRegister(0x0080, 0x8d);
lcdWriteRegister(0x0092, 0x10);
lcdWriteRegister(0x0011, 0x1b);
lcdWriteRegister(0x0012, 0x3101);
lcdWriteRegister(0x0013, 0x105f);
lcdWriteRegister(0x0014, 0x667f);
lcdWriteRegister(0x0010, 0x800);
delay(20);
lcdWriteRegister(0x0011, 0x11b);
delay(20);
lcdWriteRegister(0x0011, 0x31b);
delay(20);
lcdWriteRegister(0x0011, 0x71b);
delay(20);
lcdWriteRegister(0x0011, 0xf1b);
delay(20);
lcdWriteRegister(0x0011, 0xf3b);
delay(30);
lcdWriteRegister(0x0001, 0x2128);
lcdWriteRegister(0x0002, 0x100);
lcdWriteRegister(0x0003, 0x1030);
lcdWriteRegister(0x0007, 0);
lcdWriteRegister(0x0008, 0x808);
lcdWriteRegister(0x000B, 0x1100);
lcdWriteRegister(0x000F, 0xf01);
lcdWriteRegister(0x0015, 0);
lcdWriteRegister(0x0030, 0);
lcdWriteRegister(0x0034, 319);
lcdWriteRegister(0x0035, 0);
lcdWriteRegister(0x0036, 239);
lcdWriteRegister(0x0037, 0);
lcdWriteRegister(0x0038, 319);
lcdWriteRegister(0x0039, 0);
lcdWriteRegister(0x0050, 0);
lcdWriteRegister(0x0051, 0xf00);
lcdWriteRegister(0x0052, 0xa03);
lcdWriteRegister(0x0053, 0x300);
lcdWriteRegister(0x0054, 0xc05);
lcdWriteRegister(0x0055, 0xf00);
lcdWriteRegister(0x0056, 0xf00);
lcdWriteRegister(0x0057, 3);
lcdWriteRegister(0x0058, 0x1f07);
lcdWriteRegister(0x0059, 0x71f);
delay(20);
lcdWriteRegister(0x0007, 0x12);
delay(20);
lcdWriteRegister(0x0007, 0x13);
void lcdRegisterOther() {
Serial.println("Loading LCD registers...");
lcdWriteRegister(0x00e5,0x8000);
lcdWriteRegister(0x0000,0x0001);
lcdWriteRegister(0x0001,0x0100);
lcdWriteRegister(0x0002,0x0700);
lcdWriteRegister(0x0003,0x1030);
lcdWriteRegister(0x0004,0x0000);
lcdWriteRegister(0x0008,0x0202);
lcdWriteRegister(0x0009,0x0000);
lcdWriteRegister(0x000a,0x0000);
lcdWriteRegister(0x000c,0x0000);
lcdWriteRegister(0x000d,0x0000);
lcdWriteRegister(0x000f,0x0000);
lcdWriteRegister(0x0010,0x0000);
lcdWriteRegister(0x0011,0x0000);
lcdWriteRegister(0x0012,0x0000);
lcdWriteRegister(0x0013,0x0000);
lcdWriteRegister(0x0010,0x17b0);
lcdWriteRegister(0x0011,0x0037);
lcdWriteRegister(0x0012,0x0138);
lcdWriteRegister(0x0013,0x1700);
lcdWriteRegister(0x0029,0x000d);
lcdWriteRegister(0x0020,0x0000);
lcdWriteRegister(0x0021,0x0000);
lcdWriteRegister(0x0030,0x0001);
lcdWriteRegister(0x0031,0x0606);
lcdWriteRegister(0x0032,0x0304);
lcdWriteRegister(0x0033,0x0202);
lcdWriteRegister(0x0034,0x0202);
lcdWriteRegister(0x0035,0x0103);
lcdWriteRegister(0x0036,0x011d);
lcdWriteRegister(0x0037,0x0404);
lcdWriteRegister(0x0038,0x0404);
lcdWriteRegister(0x0039,0x0404);
lcdWriteRegister(0x003c,0x0700);
lcdWriteRegister(0x003d,0x0a1f);
lcdWriteRegister(0x0050,0x0000);
lcdWriteRegister(0x0051,0x00ef);
lcdWriteRegister(0x0052,0x0000);
lcdWriteRegister(0x0053,0x013f);
lcdWriteRegister(0x0060,0x2700);
lcdWriteRegister(0x0061,0x0001);
lcdWriteRegister(0x006a,0x0000);
lcdWriteRegister(0x0090,0x0010);
lcdWriteRegister(0x0092,0x0000);
lcdWriteRegister(0x0093,0x0003);
lcdWriteRegister(0x0095,0x0101);
lcdWriteRegister(0x0097,0x0000);
lcdWriteRegister(0x0098,0x0000);
lcdWriteRegister(0x0007,0x0021);
lcdWriteRegister(0x0007,0x0031);
lcdWriteRegister(0x0007,0x0173);
void lcdRegister7783() {
lcdWriteRegister(0x0008,0x0302);
lcdWriteRegister(0x000A,0x0008);
lcdWriteRegister(0x0010,0x0790);
lcdWriteRegister(0x0011,0x0005);
lcdWriteRegister(0x0010,0x12B0);
lcdWriteRegister(0x0011,0x0007);
lcdWriteRegister(0x0012,0x008C);
lcdWriteRegister(0x0029,0x0022);
lcdWriteRegister(0x0030,0x0000);
lcdWriteRegister(0x0031,0x0505);
lcdWriteRegister(0x0032,0x0205);
lcdWriteRegister(0x0035,0x0206);
lcdWriteRegister(0x0036,0x0408);
lcdWriteRegister(0x0037,0x0000);
lcdWriteRegister(0x0038,0x0504);
lcdWriteRegister(0x0039,0x0206);
lcdWriteRegister(0x003C,0x0206);
lcdWriteRegister(0x003D,0x0408);
lcdWriteRegister(0x0051,0x00EF);
lcdWriteRegister(0x0053,0x013F);
lcdWriteRegister(0x0060,0xA700);
lcdWriteRegister(0x0090,0x0033);
lcdWriteRegister(0x0007,0x0133);
void lcdInit() {
pinMode(LCD_CS, OUTPUT);
digitalWrite(LCD_CS, HIGH);
pinMode(LCD_RS, OUTPUT);
digitalWrite(LCD_RS, HIGH);
pinMode(LCD_WR, OUTPUT);
digitalWrite(LCD_WR, HIGH);
pinMode(LCD_RD, OUTPUT);
digitalWrite(LCD_RD, HIGH);
pinMode(LCD_RST, OUTPUT);
digitalWrite(LCD_RST, HIGH);
void lcdReset() {
digitalWrite(LCD_RST, LOW);
delay(2);
lcdWriteData(0);
lcdWriteData(0);
lcdWriteData(0);
lcdWriteData(0);
void lcdWrite8(uint16_t data) {
digitalWrite(LCD_D0, data & 1);
digitalWrite(LCD_D1, (data & 2) >> 1);
digitalWrite(LCD_D2, (data & 4) >> 2);
digitalWrite(LCD_D3, (data & 8) >> 3);
digitalWrite(LCD_D4, (data & 16) >> 4);
digitalWrite(LCD_D5, (data & 32) >> 5);
digitalWrite(LCD_D6, (data & 64) >> 6);
digitalWrite(LCD_D7, (data & 128) >> 7);
uint16_t lcdRead8() {
uint16_t result = digitalRead(LCD_D7);
result <<= 1;
result |= digitalRead(LCD_D6);
result <<= 1;
result |= digitalRead(LCD_D5);
result <<= 1;
result |= digitalRead(LCD_D4);
result <<= 1;
result |= digitalRead(LCD_D3);
result <<= 1;
result |= digitalRead(LCD_D2);
result <<= 1;
result |= digitalRead(LCD_D1);
result <<= 1;
result |= digitalRead(LCD_D0);
return result;
void lcdSetWriteDir() {
pinMode(LCD_D0, OUTPUT);
pinMode(LCD_D1, OUTPUT);
pinMode(LCD_D2, OUTPUT);
pinMode(LCD_D3, OUTPUT);
pinMode(LCD_D4, OUTPUT);
pinMode(LCD_D5, OUTPUT);
pinMode(LCD_D6, OUTPUT);
pinMode(LCD_D7, OUTPUT);
void lcdSetReadDir() {
pinMode(LCD_D0, INPUT);
pinMode(LCD_D1, INPUT);
pinMode(LCD_D2, INPUT);
pinMode(LCD_D3, INPUT);
pinMode(LCD_D4, INPUT);
pinMode(LCD_D5, INPUT);
pinMode(LCD_D6, INPUT);
pinMode(LCD_D7, INPUT);
void lcdWriteData(uint16_t data) {
lcdSetWriteDir();
digitalWrite(LCD_CS, LOW);
lcdWrite8(data >> 8);
digitalWrite(LCD_WR, LOW);
delayMicroseconds(10);
lcdWrite8(data);
void lcdWriteCommand(uint16_t command) {
lcdSetWriteDir();
digitalWrite(LCD_RS, LOW);
lcdWrite8(command >> 8);
lcdWrite8(command);
int lcdReadData() {
uint16_t result;
lcdSetReadDir();
digitalWrite(LCD_RD, LOW);
result = lcdRead8() << 8;
result |= lcdRead8();
return result;
void lcdWriteRegister(uint16_t addr, uint16_t data) {
lcdWriteCommand(addr);
lcdWriteData(data);
uint16_t lcdReadRegister(uint16_t reg) {
lcdWriteCommand(reg);
return lcdReadData();
uint16_t lcdReadID() {
return lcdReadRegister(0x00);
void lcdFillScreen(uint16_t color) {
Serial.println("Filling the screen...");
/*lcdWriteRegister(0x0050, 0);
lcdWriteRegister(0x0051, 219);
lcdWriteRegister(0x0052, 0);
lcdWriteRegister(0x0053, 319);
lcdWriteRegister(0x0020, 0);
lcdWriteRegister(0x0021, 0);
lcdWriteCommand(0x0022);
lcdSetWriteDir();
uint32_t i = 320;
i *=240;
while( i-- ) {
lcdWrite8(color >> 8);
lcdWrite8(color);
Serial.println("Done filling...");
output :
Initializing LCD...
Reading ID...0x6051
Done filling...
