Greetings friends, a doubt, you can use the 16 analog outputs for potentiometers in a mega arduino ?, I have a code that is for arduino one and does not accept me more analog inputs, try a miltiplexer and the problem is that it does not work with Hiduino , What I can do? I don't know how to program and I couldn't finish the project, I will be very grateful with your help, good vibes
Yes, you can use the 16 analog INputs to read pot's in a Mega.
A0 to A15.
You might be interested in my MIDI Controller library.
The Hiduino instructions are in the readme.
You can use this example for potentiometers:
#include <MIDI_Controller.h> // Include the library
// Create an array of new instance of the class 'Analog', called 'potentiometers'
Analog potentiometers[] = {
{A0, MIDI_CC::Channel_Volume, 1}, // pin A0, sends MIDI messages with controller 7 (channel volume) on channel 1
{A1, MIDI_CC::Channel_Volume, 2},
// Etc.
void setup() {}
// Refresh the MIDI controller (check whether the potentiometer's input has changed since last time, if so, send the new value over MIDI)
MIDI_Controller.refresh();
Pieter
