Arduino Mega 2560 and Antenova GSM shield
Hi Guys,
I have a small problem with using Arduino Mega 2560 with the antenova GSM shield. I know my code works since it work if use an Arduino Uno. But i need the extra pins which the mega supports.
So either i need to know which pins are free to use on the antenova shield??? I need 7 digitialpins.
or
Why does the shield not work with the Mega 2560. The program stop at the "GSM initializing" Any known issues with Mega/antenova? or
My code i based on this http://www.arduino.cc/en/Tutorial/GSMExamplesSendSMS
Hope you guys have time to help. Thanks
Post YOUR code HERE.
Post a LINK, not some vague hand-waving.
#include <GSM.h>
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the “READY” message to appear in the monitor. Next, type a
message to send and press “return”. Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
  • GSM shield
  • SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
// Include the GSM library
#include <GSM.h>
//#define PINNUMBER “1234”
#define PINNUMBER “”
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println(“SMS Messages Sender”);
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (notConnected) {
if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
notConnected = false;
Serial.println(“Not connected”);
Serial.println(“GSM initialized”);
Serial.print("Enter a mobile number: ");
char remoteNum[20]; // telephone number to send sms
readSerial(remoteNum);
Serial.println(remoteNum);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println(“SENDING”);
Serial.println(“Message:”);
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result) {
int i = 0;
while (1) {
while (Serial.available() > 0) {
char inChar = Serial.read();
if (inChar == ‘\n’) {
result = ‘\0’;
  • Serial.flush();*
  • return 0;*
  • if (inChar != ‘\r’) {*
    _ result = inChar;_
    * i++;*
But you don't have THE Arduino GSM shield. You have a GSM shield, of some variety, that is connected in some undefined way, to the Arduino.
Did you follow the instructions for using that shield with the Mega?
PaulS:
So the antenova shield only works with the arduino uno, by coinsedence. i need to find a sketch for the antenova shield exactly.
You can use that shield with the Mega. In a nutshell, use a jumper wire from D2 to D10 on the GSM shield.
SurferTim:
Yes, tested and it works.. Thanks :slight_smile:
